Today I Downloaded 3DS Max 2010 32 bit And when i download it it Make Like
2013/7/9:20:02:17 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:02:24 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:02:35 INGY INGY-PC === Setup ended ===
2013/7/9:20:04:16 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
2013/7/9:20:04:32 INGY INGY-PC === Setup ended ===
2013/7/9:20:04:46 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:04:47 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:04:51 INGY INGY-PC === Setup ended ===
2013/7/9:20:06:23 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
2013/7/9:20:06:25 INGY INGY-PC === Setup ended ===
2013/7/9:20:35:38 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:35:39 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:35:41 INGY INGY-PC === Setup ended ===
2013/7/9:20:36:05 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:36:07 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/9:20:36:11 INGY INGY-PC === Setup ended ===
2013/7/9:20:40:37 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
2013/7/9:20:52:05 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
2013/7/9:20:52:21 INGY INGY-PC === Setup ended ===
2013/7/12:13:30:10 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/12:13:30:14 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/12:13:30:48 INGY INGY-PC === Setup ended ===
2013/7/12:13:32:05 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/12:13:32:07 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/12:13:32:17 INGY INGY-PC === Setup ended ===
2013/7/12:13:45:32 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
2013/7/12:13:54:39 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
2013/7/12:13:54:41 INGY INGY-PC === Setup ended ===
2013/7/13:02:10:49 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/13:02:10:51 INGY INGY-PC === Setup started on INGY-PC by INGY ===
2013/7/13:02:10:58 INGY INGY-PC === Setup ended ===
2013/7/13:02:12:31 INGY INGY-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=2
Do not attempt to install this on Windows 8, as it is not compatible.
Beyond that, your error is as follows:
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
