• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    *Expert Elite*
    TravisNave
    Re: FlexLM License Cascade Problem
    04-04-2012 09:18 AM in reply to: paul.ashley
    As Darren mentioned, cascading doesn't always work as advertised.  Sometimes order listed in the .LIC file can help alleviate that.  I can tell you that the serial number makes no difference at all to the license manager.  So your reseller was confused on that fact.  And also as Darren mentioned, you can't combine a RevitArch into a Suite contract without cross-grading it.  There's probably a work around to get what you want though.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
