AutoCAD Land Desktop (Read Only)
Can you install Autocad Land Desktop on a single server?
2 REPLIES 2
938 Views, 2 Replies
So that users/clients can start the program and work across the LAN? Assuming the licensing is set up for each user, I do not want to actually install land desktop on each users computer. I think it is land desktop 2012 but not 100% certain
2 REPLIES 2
Jeff_M
The last version of Landdesktop was LDT2009, there will be no more.
As far as I know, each PC requires a separate install, either by direct installing or deployment.
TravisNave
Per the EULA, you cannot install and access Autodesk applications from the server.  This is a license violation.  Some products with special Citrix server licensing are supported.  However, Land Desktop is not one of them.
Autodesk Forums:
