Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Only close a project from the web app
I accidentally closed a project because closing projects became task for me in the CAD plugin.  Why is the ability to close a project present, as a task no less, inside the plugin?  Also there are no warnings or details what the assignment is for unless you're an Upchain pro and recognize the nomenclature.  This ability to close project outside of the web app should be removed immediately and definitely shouldn't be a task to complete.  Attached is a screen shot showing all the projects to close in the CAD plugin.
2 Comments
Status changed to: Gathering Support
Hi @adam.abernathy,
which user role are you using? Have you considered creating the project workflow which would allow only to specific role to close the project, like project manager? This would prevent other users with different roles on a project from receiving this task, and close it by mistake.
Best regards,
Andreja Schneider
adam.abernathy
Regardless of the role this ability should NOT be present in a plugin.  Since closing a project is permanent, the place that this action can be performed should be highly restricted.  And the system workflow for design projects already has the project manager to close tasks.
