RSA list of required features and problems to be fixed (Reference List)
mustafahesenow
Advisor Advisor
Message 1 of 18
mustafahesenow
Hi Guys,
I know this is maybe only our dream and Autodesk not interested about it and all our featured Ideas didn't considered  . But even though we shouldn't loose the hope and possibly every thing will be changed in the future .
For that I am posting this post to make it reference for all the required features and problems to be solved to make it easier for search and to let every body knows about it by just visiting it here .
So please Anyone has discovered problem after discussing it with our Expert @Artur.Kosakowski and support team and didnt find the solution please add this problem here as a post explaining what the problem  with link showing the original thread .
Many thanks.
#Save Our RSA.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Replies (17)
Message 2 of 18
mustafahesenow
Problem 1:
Diaphragm location of Slab the lab to be corrected (projected center of mass of the story on slab level instead of geometrical center of the slab).see link below.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/diaphragm-problem-to-be-corrected/m-p...
Mustafa Hesenow
LinkedIn
Message 3 of 18
mustafahesenow
Problem 2:
Core wall results (ability to view result of selected core wall not only altogether and results to be calculated for whole height of the core not at the center of first and last finite elements and ability to choose smoothing option (within the panel or without or global ).
https://forums.autodesk.com/t5/robot-structural-analysis-forum/diagram-of-core-walls-why-not-to-the-...
Mustafa Hesenow
LinkedIn
Message 4 of 18
mustafahesenow
Problem 3:
Improving the code combinations regulation.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/code-combination-regulation-question/...
Mustafa Hesenow
LinkedIn
Message 5 of 18
mustafahesenow
Problem 4:
Correction of Long Term Deflection calculation ACI Code For both of beams and slab and provide detail calculation note for this matter.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/immediate-and-long-term-deflection-as...
Mustafa Hesenow
LinkedIn
Message 6 of 18
mustafahesenow
Problem 5:
Correction of Short RC column design as per ACI Code (Column Interaction Diagram Capacity )
https://forums.autodesk.com/t5/robot-structural-analysis-forum/disaster-1-in-rsa-rc-column-design-ac...
Mustafa Hesenow
LinkedIn
Message 7 of 18
mustafahesenow
Problem 6:
Correction Of non sway column moment magnification procedure for Selender Column according to ACI Code (Column Design Module )
https://forums.autodesk.com/t5/robot-structural-analysis-forum/disaster-2-in-rsa-rc-column-design-ac...
Mustafa Hesenow
LinkedIn
Message 8 of 18
mustafahesenow
Problem 7:
Correction Of  sway column moment magnification procedure for Selender Column according to ACI Code (Column Design Module )
https://forums.autodesk.com/t5/robot-structural-analysis-forum/disaster-4-in-rsa-rc-column-design-ac...
Mustafa Hesenow
LinkedIn
Message 9 of 18
mustafahesenow
Problem 8:
For RC walls Design need to include buckling length and slenderness effects + need to include the out of plane moment and shear.
Mustafa Hesenow
LinkedIn
Message 10 of 18
mustafahesenow
Problem 9:
Wind simulation problems ( taking into account surrounding building obstructs , Ability to change the height and width of the wind flow )
https://forums.autodesk.com/t5/robot-structural-analysis-forum/wind-simulation-problem/m-p/7450359#M...
Mustafa Hesenow
LinkedIn
Message 11 of 18
mustafahesenow
Problem 10 :
Implementing DAM method for 2D Structures.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/direct-analysis-method-isnot-working-...
Mustafa Hesenow
LinkedIn
Message 12 of 18
mustafahesenow
Problem 11:
Enhancing the Structural Phases and ability to save the collected result with the combinations as substructure.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/phases-construction-sequences-problem...
https://forums.autodesk.com/t5/robot-structural-analysis-ideas/phase-structures-preserving-combinati...
Mustafa Hesenow
LinkedIn
Message 13 of 18
Rafacascudo
Problem 12
dampers + non linear Time History Analysis still not working
https://forums.autodesk.com/t5/robot-structural-analysis-forum/modal-analysis-and-damping/td-p/51994...
Rafael Medeiros
Message 14 of 18
mustafahesenow
Problem 13
Enhancing Construction Sequence and make it easier process  for building .
Mustafa Hesenow
LinkedIn
Message 15 of 18
Rafacascudo
Problem 14
Generated  RC tapered beam
https://forums.autodesk.com/t5/robot-structural-analysis-forum/weird-results-of-calculating-arc-cons...
old problem with taperde RC beams .Never solved .
See  https://forums.autodesk.com/t5/robot-structural-analysis-forum/rc-beam-tapered-bars-problem-with-sel...
Rafael Medeiros
Message 16 of 18
Rafacascudo
One more
stiffness values for trapezoid orthotropic panel
https://forums.autodesk.com/t5/robot-structural-analysis-forum/trapezoid-plate-stiffness-matrix/m-p/...
Rafael Medeiros
Message 17 of 18
alfredmx
Message 18 of 18
mustafahesenow
Hi @Artur.Kosakowski
Can we pin this topic on top of the posts ?
Thanks .
Mustafa Hesenow
LinkedIn
