Phases (Construction Sequences ) Problems + Questions
mustafahesenow
Advisor Advisor
Message 1 of 8
mustafahesenow
Hi Guys,
I did Model of 12 floors in order to check the phases and judge it correctly.
For defining the phases and I fallowed the same what @Pawel.Pulak did in this post.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/load-sequencing-construction-stages/m...
The additional I did is defining another load cases in the final stage Dead ,Live , Wind , and Seismic .
Then I go to result collection of the phases . And I combined the Phases self weight and compared it to SW of all the building one time It look s perfect .
Then I tried to make combinations of this phases self weight with the other loads on phases collection Base phase is the full model phase then I got some problems .
1-When I defined The combinations on the collection phases every time I go back to activate on phase then I back to the collections the combinations is deleted .Is there a way to keep them always?
2-The combinations is getting crazy For example :
    If I make commutative self weight combination   Then I combine this combination to another load is giving wrong result look only the first phase         load    activated See Attached pictures.
3-In order to have better control on the model with its results and to get the ability of saving the combinations  I decided to save it as sub structure and I got problem again with the results .
See attached pictures .
Please Advice how we can deal with model with phases to get the commutative self weight combined with other loads in order to use them in design later on .
Model attached.
https://drive.google.com/open?id=1ZsjbfWK1srdAsq-k7s_tQG-9azTMEazn
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Replies (7)
Message 2 of 8
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi Mustafa,
answers to various points of your comments.
Ad 1
Combinations defined in the collected phase are lost when repeating phase collection.
It was already in this forum post. Some improvement wish related to it is registered there.
Ad 2
Nested combinations are not supported in the collected phase of phase structures.
It is necessary to use "flat" structure of combinations in such situation - like combination 12002 in the screen capture above.
Ad 3
Saving to substructure is not supported for phase structures.
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 3 of 8
mustafahesenow
Hi @Pawel.Pulak
Many thanks for replying and answering my Questions.
Just want to ask also .
We usually reduce the stiffness of RC members for Ultimate load cases and we have different reduction factors for for service load combinations .
Reduction of cross section moment of inertia .
Is that possible by using Phases ?
Mustafa Hesenow
LinkedIn
Message 4 of 8
Pawel.Pulak
Autodesk Support
Autodesk Support
No, it is not possible.
Pawel Pulak
Message 5 of 8
mustafahesenow
Hi @Pawel.Pulak
What about having different E ?
Mustafa Hesenow
LinkedIn
Message 6 of 8
Rafacascudo
Hi MH ,
Same question some days ago. 🙂
Read Pawel's answer here
https://forums.autodesk.com/t5/robot-structural-analysis-forum/phase-analysis-thermal-loading/m-p/76...
Rafael Medeiros
Message 7 of 8
aimanalaawar
Hi @mustafahesenow,
I have defined the phases of a structure but the problem is after collecting the phases i can not display the whole structure. Please can you tell the steps to make the sequential analysiso
the structure is a 2D structure and there is an implanted column on a beam and i want to read the results on this beam
please find attached the model
Message 8 of 8
EY23
Hi @mustafahesenow,
Could you please enlighten  me about the procedure to combine phases analysis with seismic design.
shall I convert the combination SW and DL to masses? or each SW of the floor separately.
is the any video relating to this issue?
