Deleted Cladding Keeps Reappearing
anthonymctigue
anthonymctigue
Morning All,
I have run in to a rather annoying problem with a Robot model using framing that I have imported from Revit.  Essentially, the building in question has several phases so I want to run my Robot model for each phase separately.  We have set up our Revit model to isolate the various phases accordingly however, there are some RC slabs on one of the phases that keep coming through into Robot.  I can delete them on Robot however, as soon as I try to run the model, the floor slabs reappear (see below screen captures).  I have tried deleting them using a graphical select and delete as wells as deleting them from the object inspector.  I have also tried manipulating their geometry to see if I can use them elsewhere as a workaround however, again when I press calculate, Robot re-introduces extra claddings back in the original positions.
Does anyone have any insight as to how to resolve this?
anthonymctigue
Never min, I answered my own question!
I had a pressure load still applied over the areas of the plates which I could not see in the geometry view but once I deleted the area loads then the problem stopped happening.
