Diaphragm problem to be corrected
mustafahesenow
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Accepted solutions (3)
Replies (18)
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI Mustafa,
It is indeed the valid point however there are at least few concerns when you look at the 'broader' picture which include ways in which you create a model:
1. What if there are no stories in the model?
2. What if you have few modal analysis with different load to mass conversions or mass offsets (X+, X-, Y+ etc.)?
Anyway I have forwarded your comments to the development team.
Artur Kosakowski
mustafahesenow
Mustafa Hesenow
LinkedIn
mustafahesenow
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mustafa,
I'm afraid my knowledge in this area is too limited to answer yes or no on such question. Personally I think what you wrote makes sense and this is why I forwarded your comments to the development team so that they could investigate this further.
Artur Kosakowski
mustafahesenow
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mustafa,
I'll contact you off the forum for this.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I have added this request to the wish list and forwarded it to the development team.
Artur Kosakowski
okapawal
Implemented in RSA 2022 release.  The primary node for diaphragm is created at the Gravity Center of a storey projected on the floor plan.
Waldemar Okapa
Sr Product Owner
elmorro
But still individual diaphragms are created for each slab in the story
Romanich
Hi @elmorro ,
The workaround:
https://apps.autodesk.com/RSA/en/Detail/Index?id=8768390536116652588&appLang=en&os=Win64
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
b_hadjiT66B8
b_hadjiT66B8
when i try to use the diaphragmer i have a problem
all nodes are slaves to the master first storey
i use Robot Structural Analysis Professional 2025
Romanich
Hi @b_hadjiT66B8,
Please share the model
Roman Zhelezniak
b_hadjiT66B8
this is the model
Romanich
No issues at all:
Roman Zhelezniak
b_hadjiT66B8
I have identified the problem: there is no issue with the English interface, but the problem appears when using the French interface in Robot Structural Analysis 2025
b_hadjiT66B8
Romanich
Hi @b_hadjiT66B8,
Thanks for the update. I will try to check when I will have free time.
Roman Zhelezniak
