Non-Linear manual load combination for moving load
Message 1 of 15
I want to analyze the effect of a crane on a beam. The crane is modelled as travelling load. I have tension bar in my structure, which forces a non-linear analysis. When I run the analysis, Robot does not calculate results for load combinations which I have defined manually. In Analysis type diagram, I have hooked off the option for “Auxiliary case”, but after I run the analysis it is hooked on again. If I make a load combination without the travelling load, Robot can calculate forces; however it skips load combination when I have moving load in the combination.
In advance, thank you for your help.
Replies (14)
Message 2 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Make model temporaryly linear
Generate combinations as shown on example below:
Make model nonlinear again
Rafal Gaweda
Message 3 of 15
Thanks, it worked
Message 4 of 15
Rafacascudo
I´m not able to make it work. Followed the instructions. Combinations are created. No problems when Running the linear model.
When I turn it into non-linear (linear releases Rx and uz+ uplift) ,problems arise.
- In analysis parameters , everything remains "static linear"
- Ok , it runs as it is really non-linear , but as soon as it begins solving it , the loads due to my vehiche vanishes from the combinations!!!!!
http://screencast.com/t/iZpGUsRO
The only way I managed it to work was generate load cases from each moving load component and when create the combinations manually in excel
Rafael Medeiros
Message 5 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Message 6 of 15
Rafacascudo
Hi Rafal ,
I´m sending the linear model with already generated combinations.Works perfectly!
When I introduce a nonlinear element like unidirectional support or unidirectional linear release , the 6 concentrated loads due to the vehicle  vanish from the generated combinations cases
Rafael Medeiros
Message 7 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
In case nonlinear calculations you have to have real loads in real cases so do it this way (or create combinations manually with converted components)
Rafal Gaweda
Message 8 of 15
Rafacascudo
thx ,
so that´s the workaround I have done before.Create load cases from moving load components.
And that that 1st tip , make it linear, generate combination, make it nonlinear is really not working,right?
Rafael Medeiros
Message 9 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Right 😞
Rafal Gaweda
Message 10 of 15
Euge_I
I'm trying to do a P-Delta analysis with moving loads, but I have no combinations. I have arrived to these link,  but I'm not able to see the video: it sais that "the ID for this Screencast is invalid." May you describe a little what to do? Or to re-upload the video?
Sorry for the inconvenience.
Message 11 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Euge_I
Video links fixed.
Rafal Gaweda
Message 12 of 15
julie_liuMMRV7
Community Visitor
Community Visitor
Hi, I have the same problem with moving loads and the load combinations which are not running. I can't see the example, could you please resend the link. Also, what do you mean by making the model linear ? I have supports which enable an uplift so I have automatically non linear cases.
Message 13 of 15
Rafacascudo
what I understood from Rafal´s answer on 2014 is that combinations that have moving loads do not work if the model is nonlinear.
As I answered  previously ,You will have to create single load cases from moving load components and make combinations one by one
Rafael Medeiros
Message 14 of 15
festevesBEJLD
Is there a way to make an envelope load/combination with the moving load automatic cases so we can use it on design?
Message 15 of 15
Rafacascudo
Design will consider only single load cases or load combinations . Combinations which include moving loads will be considered only if they are linear.
Envelopes are not considered .
Rafael Medeiros
