Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Diaphragm problem to be corrected
18 REPLIES 18
Message 1 of 19
mustafahesenow
4674 Views, 18 Replies
1
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
18 REPLIES 18
Message 2 of 19
HI Mustafa,
It is indeed the valid point however there are at least few concerns when you look at the 'broader' picture which include ways in which you create a model:
1. What if there are no stories in the model?
2. What if you have few modal analysis with different load to mass conversions or mass offsets (X+, X-, Y+ etc.)?
Anyway I have forwarded your comments to the development team.
Artur Kosakowski
Message 3 of 19
1
Mustafa Hesenow
LinkedIn
Message 4 of 19
1
Mustafa Hesenow
LinkedIn
Message 5 of 19
Hi Mustafa,
I'm afraid my knowledge in this area is too limited to answer yes or no on such question. Personally I think what you wrote makes sense and this is why I forwarded your comments to the development team so that they could investigate this further.
Artur Kosakowski
Message 6 of 19
1
Mustafa Hesenow
LinkedIn
Message 7 of 19
Hi Mustafa,
I'll contact you off the forum for this.
Artur Kosakowski
Message 8 of 19
Hi @mustafahesenow
I have added this request to the wish list and forwarded it to the development team.
Artur Kosakowski
Message 9 of 19
okapawal
in reply to: mustafahesenow
Implemented in RSA 2022 release.  The primary node for diaphragm is created at the Gravity Center of a storey projected on the floor plan.
Waldemar Okapa
Sr Product Owner
Message 10 of 19
elmorro
in reply to: okapawal
But still individual diaphragms are created for each slab in the story
Message 11 of 19
Romanich
in reply to: elmorro
Hi @elmorro ,
The workaround:
https://apps.autodesk.com/RSA/en/Detail/Index?id=8768390536116652588&appLang=en&os=Win64
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 12 of 19
Message 13 of 19
when i try to use the diaphragmer i have a problem
all nodes are slaves to the master first storey
i use Robot Structural Analysis Professional 2025
Message 14 of 19
Romanich
in reply to: b_hadjiT66B8
Hi @b_hadjiT66B8,
Please share the model
Roman Zhelezniak
Message 15 of 19
b_hadjiT66B8
in reply to: Romanich
this is the model
Message 16 of 19
Romanich
No issues at all:
Roman Zhelezniak
Message 17 of 19
b_hadjiT66B8
I have identified the problem: there is no issue with the English interface, but the problem appears when using the French interface in Robot Structural Analysis 2025
Message 18 of 19
b_hadjiT66B8
Message 19 of 19
Romanich
Hi @b_hadjiT66B8,
Thanks for the update. I will try to check when I will have free time.
Roman Zhelezniak
