Diaphragm problem to be corrected
mustafahesenow
Advisor Advisor
Message 1 of 19
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Accepted solutions (3)
Replies (18)
Message 2 of 19
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI Mustafa,
It is indeed the valid point however there are at least few concerns when you look at the 'broader' picture which include ways in which you create a model:
1. What if there are no stories in the model?
2. What if you have few modal analysis with different load to mass conversions or mass offsets (X+, X-, Y+ etc.)?
Anyway I have forwarded your comments to the development team.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 19
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 4 of 19
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 5 of 19
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mustafa,
I'm afraid my knowledge in this area is too limited to answer yes or no on such question. Personally I think what you wrote makes sense and this is why I forwarded your comments to the development team so that they could investigate this further.
Artur Kosakowski
Message 6 of 19
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 7 of 19
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mustafa,
I'll contact you off the forum for this.
Artur Kosakowski
Message 8 of 19
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I have added this request to the wish list and forwarded it to the development team.
Artur Kosakowski
Message 9 of 19
okapawal
Implemented in RSA 2022 release.  The primary node for diaphragm is created at the Gravity Center of a storey projected on the floor plan.
Waldemar Okapa
Sr Product Owner
Message 10 of 19
elmorro
But still individual diaphragms are created for each slab in the story
Message 11 of 19
Romanich
Hi @elmorro ,
The workaround:
https://apps.autodesk.com/RSA/en/Detail/Index?id=8768390536116652588&appLang=en&os=Win64
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 12 of 19
b_hadjiT66B8
Message 13 of 19
b_hadjiT66B8
when i try to use the diaphragmer i have a problem
all nodes are slaves to the master first storey
i use Robot Structural Analysis Professional 2025
Message 14 of 19
Romanich
Hi @b_hadjiT66B8,
Please share the model
Roman Zhelezniak
Message 15 of 19
b_hadjiT66B8
this is the model
Message 16 of 19
Romanich
No issues at all:
Roman Zhelezniak
Message 17 of 19
b_hadjiT66B8
I have identified the problem: there is no issue with the English interface, but the problem appears when using the French interface in Robot Structural Analysis 2025
Message 18 of 19
b_hadjiT66B8
Message 19 of 19
Romanich
Hi @b_hadjiT66B8,
Thanks for the update. I will try to check when I will have free time.
Roman Zhelezniak
