Manual load combination warning
osekamana
osekamana
Hello forum,
I'm doing the automatic combination for seismic calculation. After setting up seismic calculation parameters I carry on with load combination when I choose automatic combination in the window that opens I check full combination and when I click ok it pops warning that says: Predefined case natures have no equivalents in the regulations EN 1990:2002. load the regulation and change load nature?
that 's how the warning is saying. I don't want to change load nature because some them were created after setting up seismic parameters
I attached both the warning and the model for you to be able to help me.
thanks a lot for your help
Obed S
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @osekamana
I think that you may answer either YES or NO and continue with the generation of load combinations. I haven't noticed any change in the load cases' natures.
Artur Kosakowski
