Void in Beam + Steel Connection not working
lglielmi
lglielmi
Hi everyone,
I just added a connection between two beams. I got advice, and my void is not able to cut the beam anymore.
Is there any correlation? Is it possible that 2024 I cannot add a ST connection and a void in the same beam?
The void is family with I cut the beam for the beam penetration; the connection is from the ST connection from Revit Steel tools.
 Has anyone experienced the same problem?
apjones
Once you add a connection, the Revit beam becomes a "fabrication" beam, and is no longer a Revit beam.
Voids in Revit no longer cut the "fabrication" elements.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
lglielmi
Thanks for the answer! Helpful!
And this is true even if I only add a steel operation, right?
This is crazy. Anyway, I've been getting used to it for ten years, trying to find an alternative solution to this software.
I even saw the opening from Autodesk (which I wouldn't say I like since I cannot create type and tag), which doesn't work on the beam with the modification. Is there a way to create openings in a fabrication element?
Since my project is almost done, the trick is not to use an RVT connection. What a pity.
Do you have any solution?
Ignus.E
Hi. You can just the opening tool in the steel tab. That will work
lglielmi
Thanks! I will go without an ST connection since I have hundreds of openings done with that.
lglielmi
@Ignus.E Is there any tool I can use in particular? Are you referring to the contour cut?
My issue is that I was using the Void family to create different types, tag them, count them, and put a symbol on the floor plan. Like this:
Is there a way to keep using the steel connection and family to create a void? (or another system to tag/count/show detail item on the floor plan)
