Hi everyone,
I just added a connection between two beams. I got advice, and my void is not able to cut the beam anymore.
Is there any correlation? Is it possible that 2024 I cannot add a ST connection and a void in the same beam?
The void is family with I cut the beam for the beam penetration; the connection is from the ST connection from Revit Steel tools.
Has anyone experienced the same problem?
Solved by Ignus.E. Go to Solution.
Solved by apjones. Go to Solution.
@Ignus.E Is there any tool I can use in particular? Are you referring to the contour cut?
My issue is that I was using the Void family to create different types, tag them, count them, and put a symbol on the floor plan. Like this:
Is there a way to keep using the steel connection and family to create a void? (or another system to tag/count/show detail item on the floor plan)
