Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Use my Revit model (or family) as a structure connection.
4 REPLIES 4
ramakant_sharma_ext
221 Views, 4 Replies
Hi i have a clamp to fix two pipes with each other, so can we save this clamp model(family) as structure connection.
How to load this model as a connection.
4 REPLIES 4
So you have saved this Structural Connection as a family? If so, you can just go to Insert - Load Family.
Yes, but I want this as a structural connection through connection option.
You can use the "Custom connection" functionallity to cover this requirement. This allows you to build a custom connection using parts and then save it as a type connection, to reuse in other instances. This workflow is not part of the family editor workflow, those actions are done in a Revit model. Once saved as a type, you can reuse it in your main model or using project transfer, transfer it to other projects (or also made it available directly in the template).
The custom connection feature is described in the Help : https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-FA037FEF-E577-4121-9614-D4BF8989DD3D .
Dumitru Berteanu
Product Owner
Forma Design Contest
