Hi i have a clamp to fix two pipes with each other, so can we save this clamp model(family) as structure connection.
How to load this model as a connection.
So you have saved this Structural Connection as a family? If so, you can just go to Insert - Load Family.
Yes, but I want this as a structural connection through connection option.
This previous topic may help you,
You can use the "Custom connection" functionallity to cover this requirement. This allows you to build a custom connection using parts and then save it as a type connection, to reuse in other instances. This workflow is not part of the family editor workflow, those actions are done in a Revit model. Once saved as a type, you can reuse it in your main model or using project transfer, transfer it to other projects (or also made it available directly in the template).
The custom connection feature is described in the Help : https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-FA037FEF-E577-4121-9614-D4BF8989DD3D .
