Adding structural connections in a revit family
4 ANTWORTEN 4
Nachricht 1 von 5
2961 Aufrufe, 4 Antworten
The title is basically the question. I need to add some connections between the wood beams of an hexagon I made as a family in Revit. But the structural steel connection that are available for the projects don't see to be available in the family template. Any suggestions?
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: Anonymous
Nest the connection families into the hexagon family. Load them into the hex family, and place them
in the locations needed. Use reference planes to align them to the framing members, etc.
Save the hex family, load into project.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
als Antwort auf: cbcarch
Thank you for your reply. I searched a bit and if I understood nesting correctly, it doesn't seem to work for the same reason when I tried to load the steel connections into project: the file is zipped, and when I try to extract it, the folder results to be empty - I work in Autocad in English, so not to make a mess I unzipped the German one. Still...
Nachricht 4 von 5
Revit Steel Connection (the steel connection button from the ribbon) only works with Steel members and only in the project environment.
If you want to do it in a family, you have to create it using the normal family creation process and nest them.
Nachricht 5 von 5
als Antwort auf: ToanDN
I see, thank you. The problem is that I am s quite new to Revit and I have never made an adaptive component nor do I know the theory behind it. Is it possible to make my family adaptive?
