Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Stairs do not appear in look up structural plan
7 REPLIES 7
Message 1 of 8
Ahmed.Ahmed962
748 Views, 7 Replies
Stairs do not appear in look up structural plan. On the contrary they appear fine on look down structural plans. Any ideas or solutions ?
Labels (3)
7 REPLIES 7
Message 2 of 8
Any help ?
Message 3 of 8
@ToanDN , @CoreyDaun@Alfredo_Medina , @constantin.stroescu , @fabiosato
Any help or knowledge about the topic?
Message 4 of 8
@hmunsell any help ?
Message 5 of 8
have you checked the view range on the properties browser , set it to a higher value and see if it helps. or check the visibilty overrides and check if it is hidden
Message 6 of 8
Yes I have! and I think this is kind of a problem with the software itself as it is not possible to view the stairs in anyway while using lookup view type
Message 7 of 8
Jason.P
in reply to: Ahmed.Ahmed962
I think this is a Revit issue. And that it will not shows stairs in the up plan on the structural side of things.
Can I as as well, as to why you need both views of your framing plan?
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Message 8 of 8
Ahmed.Ahmed962
in reply to: Jason.P
I do not both plans at the same time, but my company delivers some projects in look up and others in the look down manner
Forma Design Contest
Technology Administrators
