I don't know why my beam connect with coblum but it's have a space between
Please help me !
Thank you !
for the beams, do you have some start/end cut backs defined? (see https://forums.autodesk.com/t5/revit-structure-forum/how-to-connect-the-beam-to-the-column-without-g...)
for the columns, it should be the Offset from Attachment Top (see attached pic)
May I ask how the elements ended up in this "state"? Is it an import? Just happened? you did something in particular?
I'm asking because I'm trying to identify the source of your issue
