How to get a solid fill view when exporting 3d revit view to cadd
chhuanmawia18
chhuanmawia18
How do i get the
rebar.JPGsolid fill view when exporting 3d revit view to cadd as it appears like 2 lines when i open in cadd
hmunsell
if they are 3d Objects, all you should need to do is at the command prompt in AutoCAD, type Shade.....
you can also pick the text in the upper left of the view and pick Shaded.
Howard Munsell
_Vijay
Export form 3D view.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
chhuanmawia18
Thank you so much....
hmunsell
did that work for you :-)?
Howard Munsell
