Stairs do not appear in look up structural plan
Ahmed.Ahmed962
Ahmed.Ahmed962
Stairs do not appear in look up structural plan. On the contrary they appear fine on look down structural plans. Any ideas or solutions ?
Replies (7)
Ahmed.Ahmed962
Any help ?
Ahmed.Ahmed962
@ToanDN , @CoreyDaun@Alfredo_Medina , @constantin.stroescu , @fabiosato
Any help or knowledge about the topic?
Ahmed.Ahmed962
@hmunsell any help ?
chhuanmawia18
have you checked the view range on the properties browser , set it to a higher value and see if it helps. or check the visibilty overrides and check if it is hidden
Ahmed.Ahmed962
Yes I have! and I think this is kind of a problem with the software itself as it is not possible to view the stairs in anyway while using lookup view type
Jason.P
I think this is a Revit issue. And that it will not shows stairs in the up plan on the structural side of things.
Can I as as well, as to why you need both views of your framing plan?
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Ahmed.Ahmed962
I do not both plans at the same time, but my company delivers some projects in look up and others in the look down manner
