Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Special charactors not working ø does not work in revit 2017
2 REPLIES 2
652 Views, 2 Replies
Has anyone run into this problem in 2017 Revit
ø does not work.  Nor any of the other Alt+0177 codes Etc
2 REPLIES 2
L.Maas
Probably you are running into THIS issue described on the AUtodesk knowledge site.
If the Alt key is held too long before entering the numerical sequence when text editing, the shortcut is triggered rather than allowing the insertion of the character
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks that seems to be working.
Forma Design Contest
