After 15 year's on Architectural Desktop, the company i worked for went out of buisness and i soon realized no one used the Desktop so i have been making the transition over to Revit 2016 which is progressing along pretty good so far. Does Revit have steel grating? What are those thick colored line's for in 3d view that show up on beam's and column's. Some appear offset on some of the beam's and centered on top of some of the beam;s.
If i needed to upload a screen shot to this forum how would i do that? Thank's
Solved by Revit_Whisperer. Go to Solution.
I will address these one at a time 😃
Thank's for the reply back. I think what your saying about the grating is: e.g. Place a slab for example the thickness of the grating and assign it a surface pattern that look's like grating. As for the "analytical" i am a little confused about why i need it. Also when i add a new level some of them dupicate in the browser box. I have one heading that say's FLOOR PLANS and one STRUCTURAL PLAN'S.
