Announcements
Coping steel beam to beam not showing
davidedge
davidedge
Hi All,
I have a portal frame where two steel beams (call them A&B) come down to form a valley. There is also a steel beam (call it C) running between the portals at valley level. I want to notch A&B around C but although it appears to work at first it then goes back to showing the beam extension.
Attached below shows before and after notch, but on the second image once I un-highlight the beam on the right is when it goes back to showing the extension on the beam and no notch.
Any advice is gratefully received.
Thanks, Dave
Additionally I'm trying to change the haunch properties, is there a way to change them globally as I can only see a way to do them individually.
wojciech.badura
Hello
Could you upload model with these three elements. I cannot reproduce this problem on my example.
Thanks in advance.
WB
Wojciech B
UX Designer
davidedge
Hi, Attached a reduced version of our model. The right hand beam is notched and when I change the length I see the notch then it disappears again. Ideally I'd like to have a clip connection but again I'm having trouble getting that to work correctly.
Thanks, Dave
wojciech.badura
Thanks.
Now, I can reproduce.
I see reason of this problem. These beams with defined coping have connections created on second ends. When connection is created, geometry of connected beam is exchanged to fabrication geometry. Unfortunately, beams with fabrication geometry don’t support coping.
So.
I see only one workaround. Remove coping and create cut on beams manually by using “Opening by Face”. Openings are supported by fabrication geometry.
Regards
WB
Wojciech B
UX Designer
davidedge
Thanks for the info and understand.
I wonder is the any reason why I can't use the clip angle connection, I've tried the double clip angle too and get strange results.
Dave
davidedge
Figured it out, I have the wrong primary member selected and I need to use the skewed clip angle, doing once side at a time.
Thanks for the help diagnosing my problem in the first place. Much appreciated.
Dave
wojciech.badura
Yes, in some cases default primary element is not perfectly set.
Regards
Wojciech B
UX Designer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
