Has anyone run into this problem in 2017 Revit
ø does not work. Nor any of the other Alt+0177 codes Etc
Solved by L.Maas. Go to Solution.
Probably you are running into THIS issue described on the AUtodesk knowledge site.
If the Alt key is held too long before entering the numerical sequence when text editing, the shortcut is triggered rather than allowing the insertion of the character
Louis
Please mention Revit version, especially when uploading Revit files.
