Forums
Architecture, Engineering & Construction Community Hub
Back
Architecture, Engineering & Construction Hub
See all
Product Design & Manufacturing Community Hub
Back
Product Design & Manufacturing Hub
See all
Media & Entertainment Community Hub
Back
Media & Entertainment Hub
See all
Community Hub
Back
Community Hub
See all
Subscription, Installation & Licensing
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Forums
See all
See all
See all
Community Hub
Community Hub
See all
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Home
Revit Products Forums
Revit Structure Forum
All community
This section
This board
Knowledge base
Users
Products
Turn on suggestions
Show
only
Search instead for
Welcome to the Autodesk Revit Structure Forum. Ask questions, share your knowledge, and make connections.
Autodesk for small business
Design & Make software that works as hard as your business.
Explore today
Activity feed
Communities by language
Ask a question, share your knowledge, or submit a product idea.
Start a topic
Options
Mark all as New
Mark all as Read
Float this item to the top
Subscribe
Bookmark
Subscribe to RSS Feed
Sort by Topic Start Date
All
Trending
Accepted solutions
Unanswered
Most Viewed
Latest
Oldest
New to the Revit Structure Forum?
Start Here
Community managers
CGBenner
Revit Products Forums ideas
Share ideas for improving Autodesk products with the team that makes it and submit requests for the features that you would like to see.
Explore ideas
Related tags
" "Revit"
(13)
"Advance steel 2026"
(1)
"Annotations"
(2)
"Area Reinforcement"
(1)
"Assembly"
(2)
"asset data"
(1)
"auto join"
(1)
"Autodesk Platform Services"
(2)
"Bolted Connection"
(1)
"Bug"
(2)
"Dimensions"
(4)
"Dynamic Dimensions"
(1)
"Export to DWG"
(1)
"Export to IFC"
(4)
"Family Types"
(3)
"family"
(1)
"Filled Region"
(1)
"Floor Plan"
(2)
"Fusion360"
(1)
"Geometry"
(1)
"inctance"
(1)
"Linked models"
(2)
"miter"
(1)
"Modal Analysis"
(1)
"Nested family"
(2)
"Parameter"
(1)
"PDF"
(2)
"PDFCreator"
(1)
"PLAN VIEWS"
(2)
"printer"
(1)
"Printing"
(1)
"project browser"
(1)
"Properties"
(3)
"Rebar"
(11)
"Revisions"
(1)
"Revit 2021"
(1)
"Revit 2022"
(1)
"Revit 2023"
(3)
"Revit 2024"
(8)
"Revit 2025"
(2)
"Revit family
(3)
"Revit family"
(4)
"Revit structure"
(21)
"Revit"
(10)
"Revit" "Interoperability"
(1)
"Script dynamo"
(1)
"Section"
(1)
"SHEETS"
(1)
"SOFiSTiK"
(1)
"Structural Floor"
(1)
"Structural Plan"
(4)
"Structural Slab"
(1)
"Swept Blend"
(1)
"symbol"
(1)
"Tag"
(1)
"Unit"
(1)
"View Range"
(1)
"Wall"
(1)
***Revit encountered a serious error. The current action could not be completed.***
(1)
.dwg
(2)
.ifc Format issue
(1)
2019
(1)
2024
(2)
2024 bug
(1)
2D
(1)
3d
(1)
3D Display
(1)
3D Modeling
(1)
3D reinforcement
(5)
3D View
(1)
3DConnection
(1)
4kingelements@gmail.com
(1)
@Filters
(1)
@revit
(1)
@structure
(1)
A360
(1)
ACC
(1)
acero
(1)
Adaptative family
(3)
Adaptive family
(1)
Add Filter
(2)
add leader
(1)
Add-ons
(1)
Adjusted Range
(1)
advance steel
(5)
Advance Steel 2021
(1)
Advance Steel troubleshooting
(1)
Advanced Workflow
(1)
AdvancedSteel add-in
(1)
Advice
(1)
AEC
(1)
aec collection
(2)
AEC Webinars
(1)
AECO
(2)
Align
(1)
Alignment stadia
(1)
alternates
(1)
Altimetry
(1)
analitical
(1)
Analysis
(3)
Analysis results
(1)
Analytical
(3)
Analytical Automation
(1)
Analytical Beam
(2)
Analytical Members
(2)
Analytical Model
(16)
Analytical Modeling
(2)
analytical precast
(1)
angle
(1)
angular constraints
(1)
Annotation
(10)
annotations
(3)
Antialiasing
(1)
API
(2)
App
(1)
App Store
(1)
Arch Model
(1)
Architecture
(5)
Area Load
(3)
area reinforcement
(4)
array
(2)
Array Command
(1)
arrow
(1)
arrow head
(1)
arrowheads
(1)
Assembled Stair
(1)
Assemblies
(3)
Assembly
(4)
assembly description
(1)
Assembly for steel
(1)
Assembly Views
(1)
Assigning Uniclass Systems
(1)
associated
(1)
attach column
(1)
autocad
(1)
AutoCAD 2018
(1)
AutoCAD export issue
(1)
Autodesk CC
(1)
Autodesk ReCap
(1)
Autodesk Revit
(1)
Autodesk Support
(1)
automatic conversion
(1)
Automation
(1)
axes
(1)
axis
(1)
AXM
(1)
balustrade
(1)
Bar Bending Schedule
(1)
base plate
(1)
BBS
(1)
Beam
(27)
Beam and Clip Angle
(1)
Beam Column Join
(1)
beam cutting
(1)
beam detailing
(1)
beam element setting
(2)
Beam not supported
(1)
beam on floor plan
(1)
Beam Rebar
(3)
beam system
(1)
beam system issues
(1)
Beam System Tags
(1)
beam-column join
(1)
beams
(11)
Bending Beam
(1)
Bending Detail
(5)
Bending detail coupler sign
(1)
bends
(1)
beyond
(1)
BIM 360 PDF
(1)
BIM Interoperability
(1)
BIM Interoperability tools
(1)
BIM Learning
(1)
BIM Management
(3)
BIM REVIT
(1)
BIM360
(1)
BIMCommunity
(1)
Bind IFC
(1)
Bind link
(2)
Bind links
(1)
black and white
(1)
bolt
(1)
Bolt Anchor Diameter
(1)
Bolted Connection
(3)
Bolts
(4)
bookmarks
(1)
bracing
(2)
Bridge
(1)
bug
(1)
Bug fix
(1)
bug report
(1)
Bugs
(2)
build symbol
(1)
c channel
(1)
C4R (Collaboration for Revit)
(1)
CAD
(1)
CAD Link
(2)
CAD-CAM UXML
(1)
Callout view
(1)
canam
(1)
cantilever
(1)
Castellated Beam
(1)
Catalogs
(1)
cd phase
(1)
Ceiling
(1)
Ceiling Plans
(1)
central file
(1)
Central Model
(2)
Chinese
(1)
chord
(1)
circle
(1)
circular
(1)
Circular T shape wall with foundations
(1)
Civil
(2)
Civil 3D 2020
(2)
Civil Connection 2020.
(1)
Cladding
(1)
Clarifying question
(1)
clash
(1)
Clash Detection
(2)
Cloud
(1)
Cloud Files
(1)
CLT
(1)
cm.
(2)
CNC
(1)
CNC Plasma
(1)
COG
(1)
Coldtwisted Deformed 3d Rebar detail to be imporeved
(1)
Collaboration
(1)
collision
(1)
Color
(2)
colors
(2)
colum
(1)
Column
(9)
column cutting
(1)
column hook
(1)
column leg
(1)
column reinforcement
(1)
column schedule
(1)
Column Stack Types
(1)
Columns
(16)
component
(4)
Composite Design
(1)
Compound Sections
(1)
conceptual
(1)
concrete
(7)
Concrete Beam
(1)
Concrete Beam Joint
(1)
concrete columns
(1)
concrete slab
(1)
conexiones
(1)
connection
(10)
Connection details
(2)
Connection Setting
(1)
Connection Tags
(1)
connections
(9)
Connections - Advance Steel
(2)
connections calculation
(2)
connections design
(2)
Constrain issue
(1)
Constraints
(6)
Construction
(6)
Construction Cloud
(1)
construction design
(1)
Content Library Creation
(1)
control
(1)
Convert RFA Inventor
(1)
convert rfa to step
(1)
coordinate
(1)
Coordinate System
(2)
coordinates
(2)
coordination
(2)
Coping
(1)
Copy
(1)
copy from rvt file
(1)
copy function
(1)
copy monitor walls structure
(1)
copy revit links display settings
(1)
CopyMonitor
(1)
core
(1)
Couplers
(2)
cranked rebar
(1)
Create a Void Family with an Elliptic Profile
(1)
create rebar
(2)
Crop Region
(1)
csharp
(1)
CSIxREVIT
(1)
CSV
(1)
CT
(1)
cuantificación
(1)
curtain panel
(1)
curtain wall
(2)
curved wall
(1)
custom
(1)
CUSTOM CONNECTION
(2)
Custom Family
(2)
Custom Grid Bubbles
(1)
CUSTOM HATCH
(1)
Custom Parameters
(1)
Custom Symbol
(1)
custom truss
(1)
custome rebar
(1)
Customer Beams
(1)
cut
(1)
cut geometry
(2)
cut hatch
(1)
cut pattern
(1)
cut patterns
(1)
cut structure by void family
(1)
Cut Wall
(2)
Cut-out moved in structural framing
(1)
Cutback
(2)
cutting
(1)
Cuttoff
(1)
d
(1)
data format
(1)
Default
(1)
demolition
(1)
density
(1)
dependent views
(1)
Design
(1)
Design Options
(1)
Desktop Connector
(1)
detach
(1)
detach top
(1)
Detail
(4)
Detail Components
(1)
Detail Drawing
(1)
Detail Item
(2)
detail items
(3)
Detail Level
(2)
detail view
(1)
detailing
(2)
Detailing & Drafting Advice
(1)
Diameter
(1)
dimension
(6)
Dimensioning
(2)
Dimensioning and geometry construction
(1)
dimensions
(4)
dimensions and constraints
(1)
DIRECT SHAPE
(1)
Discipline
(1)
Display
(2)
Display Issues
(1)
Displaying
(1)
Divide
(1)
Division profile
(1)
Division Profiles
(1)
Documentation
(2)
door
(1)
doors
(1)
Drafting
(1)
Drafting View
(1)
drafting view lines
(1)
draw order
(2)
Drawing Sheet
(1)
Drawing sheet visibility
(1)
Drawings
(1)
Duplicate Types
(1)
dwg
(1)
DWG 2D
(1)
dxf
(1)
Dynamo
(11)
Dynamo Rebar
(1)
DYNAMO REVIT
(3)
Dynamo Script
(1)
edge
(1)
edges
(1)
edit
(1)
Edit Constraint
(1)
edit rebar
(1)
Edit Rebar Constraints
(2)
Editing Items
(1)
electrical substation
(1)
element
(3)
elements
(2)
elevation
(1)
Elevations
(4)
Embed Seat Plate
(1)
end plate
(1)
Energy Analysis
(1)
equality constraints
(1)
Error
(4)
Error - Getting results
(1)
error revit 2019
(1)
estructuras
(1)
etiquetas
(1)
expand to host
(1)
Export
(3)
Export 3D model
(2)
Export DWG
(2)
export PDF
(1)
export to dwg
(1)
export to NWC
(1)
Export to structural model
(1)
exporting IFC
(1)
extend to surface
(1)
extensiom
(1)
extents
(1)
extra line
(1)
extrude sketch
(1)
extrusions
(2)
Fabric sheet
(1)
Fabric Sheets
(4)
facade
(1)
Face based family
(1)
familia de etiquetas
(1)
familias
(1)
Families
(11)
Families Revit
(2)
famillies
(1)
Family
(21)
Family Building
(1)
Family creation problem
(3)
family editor
(1)
Family parameter formulas
(1)
family type catalog
(1)
Family Types
(2)
FamilyType parameter
(1)
Far clip Option
(1)
FEA
(2)
Feedback
(1)
file open
(1)
file share
(1)
Files conversion
(1)
FilledRegion
(1)
filter
(4)
filter linked arch
(1)
filtering
(2)
Filters
(5)
Flange
(1)
floor
(9)
floor edges
(1)
floor faces
(1)
floor move
(1)
floor plans
(1)
floor slab
(1)
Floor Structure
(3)
floor thickness
(1)
Floorplan issue
(1)
floors
(1)
Font
(1)
font in schedule drop to sheet
(1)
footing
(1)
footing schedule
(1)
Footing Tag
(1)
Footings
(2)
FORMA PLATFORM
(1)
formit
(1)
forms
(1)
Formula
(1)
formulas
(1)
foundation
(5)
foundation issues
(1)
Foundations
(10)
Frame
(1)
framing
(10)
framing elevations
(1)
Framing Family
(1)
free form element
(1)
Free Form Rebars
(4)
freeform
(2)
Freezing
(1)
functions
(1)
Fusion 360
(1)
Gable Connection
(1)
General
(1)
General Notes
(1)
GeneralLevel
(1)
Generating graphic
(1)
generative design
(1)
Generic Adaptive Families
(1)
generic family
(1)
Generic Model
(3)
generic models
(3)
Geometry
(1)
ghost grids
(1)
glitch
(2)
grade
(1)
graphic glitches
(2)
graphic scale
(1)
Graphical Column Schedule
(3)
graphics
(1)
Graphics & Visualization
(4)
Graphics Card
(1)
Graphics Glitch
(1)
grasshopper
(1)
greyed out
(1)
Greyed out menu
(1)
grid
(1)
grid axis
(1)
gridlines offest in views
(1)
Grids
(2)
group
(1)
Grouping
(1)
Groups
(1)
GTC file
(2)
Handrail
(1)
Hatch
(1)
Hatch Patterns
(1)
HCS
(1)
Header
(2)
helix
(1)
Help
(5)
Help & Learning
(1)
HELP ME MAKING A CHIMENY IN REVIT MODEL
(1)
Help required
(1)
hidden
(2)
hidden elements
(1)
Hidden lines
(2)
Hidden lines issues
(2)
hide
(1)
Hip Roof Framing
(1)
Hole Chart
(1)
Holes
(1)
Hollowcore Slab
(2)
Host
(1)
How to
(1)
Idea Board
(1)
ideastatica
(1)
IFC
(14)
IFC 2x3
(2)
IFC Attributes
(2)
IFC Density value
(1)
IFC Export
(12)
IFC Export Issue
(1)
IFC Exporting Issues
(7)
IFC import
(5)
IFC Links
(1)
IFC mapping
(1)
IFC Material Export
(1)
IFC parameters
(2)
IFC TEKLA TO REVIT
(2)
IFC-Export
(4)
IFC-Parameter
(1)
IFC4
(1)
IfcBeam
(1)
IFCExportConfiguration
(2)
ifcLink
(1)
Import
(2)
Import and Export
(1)
Import Error
(1)
Import IFC
(1)
Import Models
(2)
import solid
(1)
importación
(1)
Importing
(1)
Incorrectly
(1)
index color
(1)
Infrastructure
(5)
Infraworks IMX
(1)
inner walls
(1)
Insert DWG
(1)
Instalacion
(1)
instalar
(1)
Instance parameter
(1)
intellectual property
(1)
interface
(1)
Interference Check
(1)
Interoperability
(4)
Interroperrability
(1)
Inventor
(1)
Inventor to Revit
(1)
IP
(1)
isolator
(1)
Issue
(4)
ITF
(1)
join
(4)
join elements
(1)
join geometry
(1)
Join.cutback.arrows
(1)
Joining
(1)
joint
(1)
Joints
(1)
joist
(1)
Joist line type
(1)
jump
(1)
junction
(1)
key
(1)
keyboard shortcuts
(1)
Label
(2)
Label Parameters
(3)
labeling
(1)
language translation
(1)
leader
(1)
Leader arrowhead
(1)
legends
(1)
Legends from VG Filters
(1)
Length
(2)
length property
(1)
level
(1)
Level of Detail
(1)
Levels
(7)
Levels Units
(1)
Libraries
(1)
light source
(1)
Lightning Fixture Tags
(1)
Line
(2)
Line Drawing
(1)
line-based
(1)
lines
(3)
Lineweight
(1)
lineweights
(1)
Link
(3)
Link model
(1)
Linked
(1)
linked file
(2)
Linked model
(2)
linked models
(3)
Linked Models Position
(1)
linked view
(1)
Linked Views
(1)
links
(3)
list
(1)
live linking
(1)
Load
(1)
load component
(1)
loads
(1)
Location
(2)
lod
(2)
logo
(1)
Lookup
(1)
lumber
(1)
Manage links
(1)
mapping
(1)
Mapping to IFC
(1)
Marine
(1)
mass
(2)
mass density
(1)
massing
(1)
Master Central File
(1)
material
(2)
Material Appearence
(1)
material assets
(1)
Material Browser Display
(1)
Material Editor
(1)
material graphics
(2)
Material Library
(1)
Material Manager
(1)
material parameter
(1)
material properties
(2)
Material takeoff
(3)
Material updates
(1)
Material visibility
(1)
Material:volume
(1)
Materials
(1)
Materials and Rendering
(1)
Member
(1)
Member Instances
(2)
Member verification
(1)
MEP Disciplines
(1)
Merge
(1)
Merge footings in Revit
(1)
Mesh
(1)
mesh bar arrangement
(1)
Meshing errors
(1)
metal plate
(1)
Metric Units
(2)
mirror
(1)
missing components
(1)
miter cuts
(1)
mm
(2)
Model
(2)
Model groups
(1)
model importing
(1)
model in place
(1)
Model in place components
(1)
MODEL IN PLACE STAIRS
(1)
model in-place
(1)
Model Instances
(1)
model links
(1)
model tcheck
(1)
model-in-place
(1)
Modeling
(9)
Modeling Drawing
(1)
Modeling flexibilites
(1)
Modelling
(3)
Modifiers
(1)
mouse drag
(1)
move
(3)
Move with grids
(1)
multi
(1)
Multi-Discipline
(2)
Multi-Rebar Annotation
(3)
multiple leaders
(1)
multirebartag
(1)
Naviate
(2)
Naviate REX
(1)
navisworks
(2)
nc
(1)
NC File
(1)
NC output
(1)
nested
(2)
Nested Component
(1)
Nested Families
(4)
nested family
(1)
No Error
(1)
No weight in steel members - Revit Structure
(1)
nominal weight
(1)
NON_POS_LENGTH
(1)
Not listed
(1)
Not working
(1)
Notches
(1)
note block
(1)
Nudge
(1)
numbering
(1)
Numbers
(1)
Object styles
(1)
Old Building
(1)
Omniclass
(1)
Options
(1)
organization
(1)
Orient View
(1)
orientation
(1)
overconstrained reference planes
(1)
overhead element
(1)
Overlays
(1)
Override color
(1)
parameter
(3)
Parameter formulas
(2)
Parameters
(8)
parameters concatenation
(1)
parametric
(2)
Parametric Drawing
(1)
parapet walls
(1)
part
(1)
Parts
(2)
parámetros
(1)
path
(1)
patterns
(1)
PBP
(1)
PDF
(1)
pdf export
(1)
PDF export issue
(1)
PDF Exporter
(1)
PDF Issues
(1)
PDF Print
(1)
Performance
(1)
performance issues
(1)
pernos
(1)
Phase
(1)
phase overrides
(1)
phases
(2)
Phasing
(1)
Physical element
(1)
pick support
(1)
pier
(1)
Pier Cap Family
(1)
Pile
(1)
Pile Caps
(1)
PileFoundation
(1)
pipe
(1)
Piping
(1)
plan region
(2)
Plan Region in Structural plan
(2)
plan regions
(1)
plan views
(2)
planificación
(1)
Planning
(1)
Plate
(2)
Plate Type
(1)
Please help
(1)
plugin
(1)
plugins
(1)
point
(1)
Point Cloud
(1)
point clouds
(1)
polyline
(1)
post
(1)
Post and beam connections
(1)
post tensioning
(1)
power transformer
(1)
Precast
(16)
precast column
(2)
precast gap
(1)
precast slabs
(1)
precast structure
(1)
precast structures
(1)
precast tolerance gap
(1)
precast wall panel
(1)
Precision
(1)
print
(1)
Print PDF
(2)
Print sheet
(1)
Print to PDF
(1)
Print View
(1)
printing
(2)
printing sheets
(1)
Printing to PDF
(2)
problem
(1)
Project base point
(2)
Project browser
(4)
project parameters
(1)
Propagate Connection
(1)
Properties
(1)
properties palette
(1)
Properties Panel
(1)
purlin
(1)
python
(1)
QOL
(1)
quantities take off
(1)
quantity
(1)
radial
(1)
radial array
(1)
Radius Array
(1)
Railing
(2)
Railing Creation
(1)
Railing Extension
(1)
Railing issue
(1)
railway
(1)
Ramps
(1)
ray lines
(1)
RC BEAM
(1)
Reabr Shape family
(1)
Rebar
(80)
rebar 2025 Label
(1)
Rebar Arc shape
(1)
Rebar Basis
(1)
Rebar Constrains
(1)
Rebar coupler
(1)
rebar cover
(2)
rebar detail components
(1)
Rebar Detailing
(34)
rebar elements
(6)
rebar modeling
(2)
Rebar Navisworks
(1)
rebar number
(1)
rebar numbering
(1)
rebar numbers
(1)
Rebar Placement Problem
(1)
Rebar schedule
(4)
rebar shape
(1)
Rebar Shapes
(5)
Rebar View Filter
(1)
rebar visibiliy
(1)
RebarDetailing
(1)
rebars
(2)
ReCap
(1)
RECAP PRO 2026
(1)
recess
(1)
Recommendations | Opinions
(1)
reference plane
(1)
reference planes
(1)
references
(1)
reflected ceiling plan
(1)
reinforced concrete
(2)
Reinforced walls
(1)
Reinforcement
(27)
reinforcement cutout
(1)
Reinforcement Quantity
(2)
reinforcements
(1)
reinforcing
(2)
RENAME
(1)
Rendering Problem
(1)
retaining wall
(2)
revert after sync
(1)
Revision Cloud
(1)
Revision Cloud Table
(1)
Revision Clouds
(1)
RevisionSettings
(1)
Revit
(120)
REVIT - 2016
(2)
REVIT - 2018
(1)
Revit - 2019
(1)
REVIT - 2020
(9)
REVIT - 2021
(23)
Revit - 2022
(4)
Revit - Advanced Steel
(1)
Revit 2015
(1)
Revit 2018
(3)
Revit 2019
(5)
Revit 2020
(16)
Revit 2020.0
(1)
Revit 2021
(7)
Revit 2021 - Fabrication Shapes
(1)
Revit 2021 Help
(1)
Revit 2021 render
(1)
Revit 2021 Structure
(3)
Revit 2021 Updates
(1)
Revit 2022
(12)
REVIT 2022 GRAITEC POWERPACK EXTENSION MESSAGE
(1)
REVIT 2023
(8)
Revit 2023 Analytical Automation
(2)
Revit 2024
(4)
Revit 2024 issue
(1)
revit 2024.2
(1)
revit 2025
(2)
Revit 2026
(1)
Revit 2026 error
(1)
Revit 23. BIM Interoperability Tools
(1)
Revit analysis
(1)
Revit analytical
(2)
Revit and Robot Integration
(1)
Revit API
(2)
Revit Architecture
(1)
REVIT BOLTS
(1)
Revit compatibility with Cloud Storage
(1)
revit connection
(1)
revit design
(1)
Revit Dynamo
(1)
REVIT ERROR
(1)
Revit Export
(1)
Revit Extension
(2)
Revit families
(1)
REVIT FAMILY
(11)
REVIT FAMILY BEAM TAG CUSTOM STRUCTURAL
(1)
Revit family creation
(2)
Revit File Conversion
(1)
Revit footing different thickness
(1)
Revit formula
(1)
REVIT Graphisme
(1)
Revit Help
(1)
revit licence
(1)
Revit link model
(2)
Revit Linked Files
(1)
Revit Links
(2)
Revit massing
(1)
Revit Materials Library Install
(1)
revit model
(1)
Revit model checker
(1)
revit niew
(1)
Revit Parameter
(1)
Revit Parameters
(1)
Revit pipes
(1)
Revit Plugin
(1)
Revit precast
(3)
Revit precast walls
(1)
Revit products
(1)
Revit Railing
(1)
Revit Rebar
(7)
Revit Rebar Detailing
(1)
Revit Reinforcement Documentation with Robot
(1)
Revit roof
(1)
Revit Schedule
(2)
Revit Schedules
(3)
Revit Shared Coordinates from Civil 3D
(1)
Revit Shared Parameters
(2)
Revit sheet 2021
(1)
Revit stairs analytic
(1)
revit stairs froze
(1)
Revit Steel Connection
(5)
revit steel connections
(1)
Revit structural
(9)
Revit Structural Beams
(2)
Revit structural columns
(5)
Revit structural framing
(2)
Revit structural truss clash
(1)
Revit structural trusses
(4)
Revit StructuralBeam
(1)
Revit Structure
(44)
(1)
Revit Structure Rebar
(7)
Revit Structures
(2)
Revit Structures 2022
(1)
REVIT TEKLA EXPORT
(1)
Revit Templates
(1)
revit to cad
(1)
Revit to IFC export
(1)
Revit to Robot Link
(1)
Revit tools
(1)
Revit Troubleshooting
(1)
Revit Tutorials
(1)
REVIT Walls to Analylical Walls
(1)
Revit with Graitec
(1)
Revit-structural-design-professional
(1)
Revit-Textveschiebung-komischdargestellt nach der Öffnung ein Modell von Kollege
(1)
revit2019
(2)
Revit2020
(1)
revit2021
(1)
REVIT2022
(5)
Revit2024
(2)
Revit2025
(1)
RevitCommunity
(1)
RevitLinkInstance
(1)
RevitStructuralBeam
(1)
RevitStructure
(1)
revitstructure footing import
(1)
REVİT
(1)
revt
(1)
Rex
(1)
REX Framework
(1)
rfa
(3)
RFA to STEP
(2)
RGB
(1)
Rhino
(1)
RISA 3D
(2)
RISA-REVIT LINK
(1)
Robot
(5)
Robot 2022
(1)
ROBOT Display section Shape
(1)
Robot Structural Analysis
(5)
Robot Structural analysis 2021
(1)
Robot Structural Analysis Software
(1)
Roof
(4)
roof slabs
(1)
Root
(1)
rotate
(1)
rotate in elevation
(1)
rotation
(3)
Rotation Issue
(1)
rotation revit
(1)
Round structure
(1)
RVT export
(1)
s-hook rebar
(1)
scale
(2)
Scheduels
(1)
Schedule
(17)
Schedules
(10)
scope box
(1)
Scope Box Alignment
(1)
Scope Boxes
(1)
SDS2
(1)
section
(2)
section numbring
(1)
Section via grid line
(1)
section view
(1)
section views
(1)
Sections
(3)
seismic insulation
(1)
Selected Category
(1)
Selection Highlight
(1)
Selector
(1)
Settings
(1)
shaft
(2)
Shaft Opening
(1)
shape code 34
(1)
Shared Parameters
(1)
sheet
(1)
sheet list
(1)
Sheet Manager
(1)
sheets
(2)
Sheets Revit
(1)
shop drawing
(1)
Shop Drawings
(3)
SHORTCUT KEYS
(1)
shortcuts
(2)
Shorten
(1)
Site Monitoring
(1)
Skewed rebar
(1)
slab
(7)
slab - wall joint
(1)
slab edge
(3)
slab egde
(1)
Slab reinforcement
(2)
Slanted Column
(1)
slanted columns
(1)
sleepers
(1)
slope
(1)
sloped floors
(1)
sloped joist
(1)
Sloped piles
(1)
sloped slabs
(1)
Sloped Wall
(1)
slopes
(3)
slow
(1)
smart dimensions
(1)
SMLX
(2)
Snap
(2)
Snaps
(2)
soffit
(1)
Space Bar Functionality
(1)
spacegass
(1)
spacing
(1)
Span direction
(1)
span direction symbol
(1)
Specification
(1)
spiral staircase railing
(1)
splice
(4)
spline
(1)
spline through points
(1)
split
(1)
Split Element
(1)
spot coordinate
(1)
Spot elevation
(5)
Srtucture
(1)
stair
(2)
Stair Layout
(1)
stair tread
(1)
Stairs
(9)
stairs stair step
(1)
Standard Details
(2)
steel
(12)
steel beam
(1)
Steel beam miter connection
(1)
steel connectins
(1)
Steel connection
(10)
Steel connections
(13)
Steel design
(1)
Steel detailing
(1)
steel embedded in concrete
(1)
Steel Frame
(2)
steel framing
(1)
Steel Modifiers
(1)
Steel Profile
(1)
steel quality
(1)
Steel sections
(1)
steel stairs
(1)
Steel Structure
(14)
steel structures
(4)
steel trusses
(1)
Steelwork
(2)
STEP
(1)
stirrups
(1)
STP
(1)
stringer
(1)
structre
(1)
Structual Analysys
(2)
Structural
(20)
Structural Analysis
(2)
structural beams
(2)
Structural Column
(9)
Structural Column Issue
(1)
structural columns
(3)
Structural Connection
(7)
Structural Connection Revit
(1)
Structural connections
(12)
structural connections in Revit 2024
(1)
Structural Design
(1)
Structural Drawings
(1)
Structural elements
(3)
Structural Family Beam Column
(1)
Structural Foundation
(4)
Structural Framing
(35)
structural framing tags family
(3)
structural opening
(1)
Structural Openings
(2)
structural plan
(3)
structural plans
(1)
Structural Precast Extension for Revit 2019
(1)
Structural Precast for Revit
(3)
Structural rebar
(3)
structural stairs
(1)
Structural Steel
(7)
structural tag
(1)
Structural Usage
(1)
Structural View
(1)
Structural Wall
(1)
Structural wall types
(1)
Structural Walls
(1)
Structural workflow
(2)
Structure
(51)
Structure Framing
(1)
structure modelling
(4)
Structure Types
(1)
STRUCTURES
(14)
Sturctural Deck
(1)
Sturcture
(1)
subfolder
(1)
substation
(1)
Support
(1)
Supported File Format
(1)
Surface contacts
(1)
surface pattern
(1)
switch join order
(1)
Switzerland
(1)
sycn with central
(1)
symbol
(3)
symbolic line
(1)
symbolic lines
(1)
symbols
(1)
system family
(3)
System Parameters
(1)
Tab
(1)
Tables
(1)
TAG
(5)
TAG ADD REBAR
(1)
Tag by Categories
(1)
Tag elements
(3)
tag family
(1)
Tag Rebar
(5)
Tagging
(3)
tags
(7)
Take off
(1)
Tapred
(1)
tekla
(3)
Tekla ifc
(1)
Tekla to Revit
(1)
Template
(2)
template file
(1)
Templates
(1)
Temporary View Properties
(1)
text
(1)
text box
(1)
text editing
(1)
Text Size
(1)
Text Snaps
(1)
third party load combinations
(1)
Timber
(3)
Title Block Issue
(1)
tolerances
(1)
top chord
(1)
top connection
(1)
topography
(1)
Topography Revit
(1)
TopographySurface
(1)
Toposolid
(2)
toposolid structural
(1)
tornillos
(1)
Total Quantity
(1)
Transitions
(1)
Transparency
(3)
tread
(1)
triangulation
(1)
truss
(8)
Truss loading on beam
(1)
truss sytem
(1)
Trusses
(1)
Tube and pipe
(1)
Tunnel
(1)
TXT
(1)
Type
(2)
uniones
(1)
unistrut
(1)
unit issue
(1)
units of measure
(1)
universidad
(1)
update
(1)
update issues
(1)
Upgrade Issues
(1)
upgrade model
(1)
User Interface
(5)
variable
(1)
variável
(1)
varying
(3)
varying rebar set
(1)
Vertical Brace
(1)
vertical opening
(1)
vertical rotation
(1)
VG
(1)
View
(2)
View problem
(1)
View Range
(5)
view range problem
(1)
View Representations
(1)
view template
(1)
View Title
(1)
Views
(5)
ViewSheet
(1)
visibility
(2)
visibility and graphics
(1)
visibility graphics
(2)
Visualization
(4)
void
(3)
Void Cut
(1)
void cutting
(1)
Void Extrusion
(2)
void family
(1)
Voids
(1)
Volume
(4)
wall
(11)
wall cut
(2)
wall family
(1)
Wall Footings
(1)
wall join
(1)
wall joint
(1)
wall layers
(1)
Wall opening
(6)
Wall Profiles
(1)
Wall Slab Join
(1)
wall tag
(1)
Wall tapered with top slop
(1)
wall-roof attachment
(1)
walls
(11)
Walls in Revit
(2)
Walls Issue
(1)
warning
(1)
Warnings
(1)
Webinar
(1)
Weld Symbol
(2)
Weldments
(1)
Welds
(1)
Width
(1)
wind simulation
(1)
Window family
(1)
windows
(1)
Wire Mesh
(2)
witness
(1)
Wood
(5)
Wood Beams
(1)
Wood Floor Truss interfacing Wall
(1)
wood frames
(1)
wood structure
(1)
Wooden Beams
(1)
woodwork
(1)
Work Plane
(1)
work set
(1)
workset
(2)
workshared
(1)
Worksharing
(2)
wrap
(1)
wrong represention
(1)
XML
(1)
yes-no
(1)
Previous
Next
Event
[WEBINAR] Autodesk Informed Design in Action: Real Workflows with Gaylor Electric
Apr 30, 2026
9:00 AM US/Pacific
See all events
Top contributors
User
Count
jay_colc
5
GaryOrrMBI
1
View All
Trending topics and solutions
Blog
Georeferencing BIM using Revit
Friday, April 17, 2026
Blog
More Sign-In Options for Autodesk Accounts
Monday, April 6, 2026
Blog
Establishing Shared Coordinates Between Revit and Civil 3D
Tuesday, March 17, 2026
Blog
Seeing Force, Not Form: How Perception Shapes Generative Design
Monday, January 26, 2026
Blog
Bionic & Parametric Design in Revit: Breaking the “Wow Effect” into Simple Steps
Monday, November 10, 2025
Blog
Why I Applied to Autodesk Expert Elite – People Behind the Pixels
Thursday, September 11, 2025
Blog
Bill of Materials and Equipment (BOM) in Autodesk Revit
Thursday, August 28, 2025
Blog
How Do You BIM - Ok, Now Lets Bring That ReCap Mesh Into Revit
Wednesday, August 27, 2025
Blog
Revit & MCP Learn about LLM+Revit 2 through the case : Implement multiple chains of thought
Monday, August 4, 2025
Blog
How Do You BIM - lets take a look at ReCap Mesh
Thursday, July 24, 2025
Blog
Use MCP In Revit
Thursday, July 3, 2025
Blog
How Do You BIM - DeMystifying Shared Parameters
Monday, June 16, 2025
See all trending topics and solutions
Related product news and updates
Blog
Autodesk Revit 2027: Comparing Two AI Approaches and Breaking Down Key Updates
Monday, May 4, 2026
Read
Bookmark
Blog
Read
Bookmark
Blog
Read
Bookmark
See all related product news and updates
Related tips and tutorials
Tips
Benefiting Revit users from ISO 19650 (Information Management) #1
Wednesday, April 22, 2026
Read
Bookmark
Tips
Read
Bookmark
Tips
Use Content Catalog for Project Starter files.
Thursday, March 19, 2026
Read
Bookmark
See all
