Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Measure centre of bolt holes
11 REPLIES 11
Message 1 of 12
prgnti
2158 Views, 11 Replies
Why is it not possible to measure to the centre of bolt holes in Revit 2019? Seems like a basic function to me. Or am I missing something? See attached screencast.
11 REPLIES 11
Message 2 of 12
YarUnderoaker
in reply to: prgnti
Message 3 of 12
prgnti
in reply to: YarUnderoaker
I am aware that there's no problem with measuring to centre of bolts. I would like to measure to centre of bolt holes.
Message 4 of 12
múinteoir
in reply to: prgnti
Its does not seem possible even after switching to wireframe mode
Jonathan Hand
Technology Manager - Symetri Tech
 autodesk-expert-elite-member-logo-1line-rgb-black
twitterNaviate
Message 5 of 12
mihai.sandu
in reply to: prgnti
Hi guys,
At the present moment Hole Centers and Shear Stud centers can't be dimensioned. We are working to enable this in a future version.
The Help Documentation contains several limitations on Tags and Dimensions.
Mihai Sandu
Sr. QA Analyst
Message 6 of 12
Any update on this? It's kind of annoying using drafting workarounds on something where you can actually see when hovering over a hole, you can dimension the diameter or radius, but not the actual setout.Hole.jpg
Simon Whitbread
BIM Consultant
Formally known as WHITBRS
Message 7 of 12
snadesign1
in reply to: SimonWhitbread
to add dimension to hole center, just draw a short line (those lines can snap to the arc of the holes) and snap to your newly added line instead.
Message 8 of 12
SimonWhitbread
in reply to: snadesign1
You mean use the annoying drafting workaround I was specifically not wanting to do?
Simon Whitbread
BIM Consultant
Message 9 of 12
not this year then? 🙂
Simon Whitbread
BIM Consultant
Message 10 of 12
Va3ilem
Not real solution but works
Message 11 of 12
prgCEP9G
in reply to: Va3ilem
I had totally forgot about this post 🙂 This problem was solved in Revit 2022 or 2023 but thank you so much for your sugested solutions.
Message 12 of 12
and.magro
in reply to: prgCEP9G
And so, what's the solution? Wireframe style display?
Forma Design Contest
