Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Measure centre of bolt holes
13 REPLIES 13
Message 1 of 14
prgnti
2310 Views, 13 Replies
Why is it not possible to measure to the centre of bolt holes in Revit 2019? Seems like a basic function to me. Or am I missing something? See attached screencast.
13 REPLIES 13
Message 2 of 14
YarUnderoaker
in reply to: prgnti
Message 3 of 14
prgnti
in reply to: YarUnderoaker
I am aware that there's no problem with measuring to centre of bolts. I would like to measure to centre of bolt holes.
Message 4 of 14
múinteoir
in reply to: prgnti
Its does not seem possible even after switching to wireframe mode
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 5 of 14
mihai.sandu
in reply to: prgnti
Hi guys,
At the present moment Hole Centers and Shear Stud centers can't be dimensioned. We are working to enable this in a future version.
The Help Documentation contains several limitations on Tags and Dimensions.
Mihai Sandu
Sr. QA Analyst
Message 6 of 14
Any update on this? It's kind of annoying using drafting workarounds on something where you can actually see when hovering over a hole, you can dimension the diameter or radius, but not the actual setout.Hole.jpg
Simon Whitbread
BIM Consultant
Formally known as WHITBRS
Message 7 of 14
snadesign1
in reply to: SimonWhitbread
to add dimension to hole center, just draw a short line (those lines can snap to the arc of the holes) and snap to your newly added line instead.
Message 8 of 14
SimonWhitbread
in reply to: snadesign1
You mean use the annoying drafting workaround I was specifically not wanting to do?
Simon Whitbread
BIM Consultant
Message 9 of 14
not this year then? 🙂
Simon Whitbread
BIM Consultant
Message 10 of 14
Va3ilem
Not real solution but works
Message 11 of 14
prgCEP9G
in reply to: Va3ilem
I had totally forgot about this post 🙂 This problem was solved in Revit 2022 or 2023 but thank you so much for your sugested solutions.
Message 12 of 14
and.magro
in reply to: prgCEP9G
And so, what's the solution? Wireframe style display?
Message 13 of 14
FYI its 2024 and we're still waiting.....Autodesk can you make actully fix all of these ongoing issues rather than the answer being 'that can easily be done with Dynamo'
Message 14 of 14
prgCEP9G
in reply to: and.magro
No, you just have to snap to the hole centre. A small blue dot appears, click and you're done. Any visual style will do.
