Hello!
Is anyone figured out some workaround for Independent justification points for structural steel fabrication element ?
Bracing element end offset independent for both ends? For fabrication elements this option in instance parameters is disabled.
Hi!
Yes, but for "Fabrication elements" , those elements wich had edited with Steel tab tools.
Hi Mr.Berteanu, I hope you are doing well.
What is the solution for the above question? I have faced the same problem in my projects.
