Hello!
Is anyone figured out some workaround for Independent justification points for structural steel fabrication element ?
Bracing element end offset independent for both ends? For fabrication elements this option in instance parameters is disabled.
Hello!
Hi!
Yes, but for "Fabrication elements" , those elements wich had edited with Steel tab tools.
Hi!
You are right my friend. It gets disabled for "Fabrication Elements".
Let me tag community manager to help you out
Hi Mr.Berteanu, I hope you are doing well.
What is the solution for the above question? I have faced the same problem in my projects.
