Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Independent justification points for structural steel fabrication element
4 REPLIES 4
GatisM
275 Views, 4 Replies
GatisM
Hello!
Is anyone figured out some workaround for Independent justification points for structural steel fabrication element ?
Bracing element end offset independent for both ends? For fabrication elements this option in instance parameters is disabled.
Hello!
4 REPLIES 4
farzanbayat74
in reply to: GatisM
farzanbayat74
@GatisM
Are you looking for this ?👇
@GatisM
GatisM
in reply to: farzanbayat74
GatisM
Hi!
Yes, but for "Fabrication elements" , those elements wich had edited with Steel tab tools.
Hi!
farzanbayat74
in reply to: GatisM
farzanbayat74
@GatisM
You are right my friend. It gets disabled for "Fabrication Elements".
Let me tag community manager to help you out
@GatisM
farzanbayat74
in reply to: GatisM
farzanbayat74
@DumitruBerteanu
Hi Mr.Berteanu, I hope you are doing well.
What is the solution for the above question? I have faced the same problem in my projects.
@DumitruBerteanu
