Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit 2015 Duplicate sheets
11 REPLIES 11
Message 1 of 12
15683 Views, 11 Replies
I'm using Revit MEP 2015 and im staggered that you cannot duplicate a Sheet. So am i right in saying that once you finish your 1st sheet with info filled in, views and legends inserted there is no way to duplicate this? You have to do each sheet one at a time?
Or does anyone know of an App i can download?
Many thanks
Paul
11 REPLIES 11
Message 2 of 12
L.Maas
In your project browser if you select multiple sheets you can fill the instance parameters at once in the property window.
But you can not copy a sheet. This is because most views are only allowed to be placed once on a sheet.
It is something that is requested on a regular basis to be able to copy sheets with placeholders or something.
You can always put in a request of your wishes to autodesk by fiklling in the form on THIS autodesk site.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 12
in reply to: L.Maas
Many thanks for your reply. Yes i know that side of it where you can fill in the attributes as such, but its the standard notes or legends that might be required on multiple drawings plus the main view can be removed and another substitued in maybe as the floors go up?
OK, sounds like its one by one then, Thanks!
Paul
Message 4 of 12
L.Maas
Maybe some things can be done through the API. In that respect dynamo might be an option.
Louis
Message 5 of 12
CADTripper
Yes you are right there is no way in Revit to duplicate sheets at the moment. The quickest way is to prepare a placeholder sheets in your template as many as you think you need in every project and use it when creating new sheets for your project legends. Make sure you are utilizing the Revit Legends for your "legends and general notes" to use it as many times as you want and insert it in multiple sheets.
For views like drafting, floor plans, sections, etc. you have to duplicate it to be able to insert it in multiple sheets and re-use the same view.
Ryan
Ryan Ortega
MEP BIM Lead
Aurecon Group - Dubai, UAE
www.ryanortega-bimportfolio.com
Message 6 of 12
in reply to: L.Maas
Dynamo was my thought here too. There are some cool classes on the AU website that detail this exact activity. It's mega easy and opens the door to loads more possibilities.
Message 7 of 12
You can purchase and download the app for Duplicate sheet, very fast and safe.
Thanks !!
Message 8 of 12
Select the sheet and Ctrl+C and Ctrl+V will do what you want.
regards
Christian
Message 9 of 12
So you have to purchase a plug-in to bypass what should otherwise be a regular feature?
Message 10 of 12
L.Maas
As mentioned in earlier post, you could do things with Dynamo. Dynamo is now integral part of Revit.
Louis
Message 11 of 12
in reply to: L.Maas
iam working on architectural revit 2018   i knew  that duplicate a sheet is not possible, but what if i want to do the same exact sheet but with  2 different  visual styles, is that possible?  thanks
Message 12 of 12
brobes05
This solution worked for me quickly (only about 5 dynamo nodes):
https://www.youtube.com/watch?v=31BpVwrzq-A
Forma Design Contest
Technology Administrators
