I'm using Revit MEP 2015 and im staggered that you cannot duplicate a Sheet. So am i right in saying that once you finish your 1st sheet with info filled in, views and legends inserted there is no way to duplicate this? You have to do each sheet one at a time?
Or does anyone know of an App i can download?
Many thanks
Paul
In your project browser if you select multiple sheets you can fill the instance parameters at once in the property window.
But you can not copy a sheet. This is because most views are only allowed to be placed once on a sheet.
It is something that is requested on a regular basis to be able to copy sheets with placeholders or something.
You can always put in a request of your wishes to autodesk by fiklling in the form on THIS autodesk site.
Louis
Please mention Revit version, especially when uploading Revit files.
Many thanks for your reply. Yes i know that side of it where you can fill in the attributes as such, but its the standard notes or legends that might be required on multiple drawings plus the main view can be removed and another substitued in maybe as the floors go up?
OK, sounds like its one by one then, Thanks!
Paul
You can purchase and download the app for Duplicate sheet, very fast and safe.
Thanks !!
As mentioned in earlier post, you could do things with Dynamo. Dynamo is now integral part of Revit.
Louis
iam working on architectural revit 2018 i knew that duplicate a sheet is not possible, but what if i want to do the same exact sheet but with 2 different visual styles, is that possible? thanks
This solution worked for me quickly (only about 5 dynamo nodes):
https://www.youtube.com/watch?v=31BpVwrzq-A
