Revit MEP Forum
pipe end caps/plugs change with size
17 REPLIES 17
Message 1 of 18
1256 Views, 17 Replies
hi,
we have a family (custom) of caps for the plug/end cap of a pipe.  issue is when the pipe changes (ex. 4" to 6"), the family changes to the default.  that is, our family (with attendant info) vanishes and the new cap is the one set in the pipe routing settings (default).  it seems revit treats the new pipe size as a new pipe.  we wish to keep our assigned family to the pipe and not have another magically show up.  causes extra time to sweep the documents looking for accidental swaps.
thanx in advance,
karl
17 REPLIES 17
Message 2 of 18
RobDraw
@Anonymouswrote:
hi,
thanx in advance,
karl
What you are describing is how routing preferences work. If you prefer a different cap, make another pipe type with that cap in the routing preferences. Alternatively, you can add another cap to the current type and hope that it sticks. I get mixed results with this approach though.
Rob
Message 3 of 18
in reply to: RobDraw
thanx, I don't want the extra pipe definition (more makes for more complicated, I prefer KISS approach).
I tried the "other cap" & no, it does not stick.
Message 4 of 18
robert.klempau
Hello @Anonymous,
It looks like there are several endcap families in your project and set in the routing preferences of your Pipe Type to different sizes.
Please check the routing preferences of your Pipe Type.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 5 of 18
in reply to: robert.klempau
thanx, I'm aware of this dialog box & no it's not the solution to my issue.  there is only one cap assigned.  our family has 3 versions (with associated info) & the schedules can distinguish the 3 versions.  but when a pipe size changes, the "assigned" cap in this dialog is placed & not the current assigned family.  (i.e. an unintended swap-out)
Message 6 of 18
robert.klempau
Hello Karl,
can you send me the family so I can have a look at it?
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 7 of 18
rcscarvalho
Hi @Anonymous,
Does your cap family has types for each size or are the sizes changed by lookup table/formulas?
Renan Carvalho
BIM Specialist na MHA Engenharia
Revit MEP, Structure e Architecture ACP
Message 8 of 18
in reply to: rcscarvalho
I'm using the ootb "Plug - PVC - Sch 40 - DWV.rfa" & then edited (& renamed) for my needs.  it's not the family.  revit places a new instance when the pipe size changes.  the family does use the lookup table "Plug - PVC - Sch 40 - DWV" so I would say, yes, this could be the source of "new instance".
Message 9 of 18
RobDraw
So, you would rather keep going with what is not working than set up a pipe type with the routing preferences that you want to "stick"? It sounds like the second S is the priority rather doing it smartly.
Good luck.
Rob
Message 10 of 18
sorry you feel that way.  we have 12 pipe types & 9 more would be needed for caps/plugs to look nice.
Message 11 of 18
RobDraw
So, you would rather have to change the cap type rather than create a pipe type that suits your needs. Doesn't seem very smart to me. There are different duct types in Revit OOTB just for different routing preferences. This is the way Revit works. Fighting the system is only going to cause problems. KISS and go with the flow. You might be fighting a losing battle.
Rob
Message 12 of 18
debimmanager
I think what you're needing is this, right?
Kudo if you consider it and mark as a solution if it helps you solve your issue.
Thank you!!
Deivis E.
REVIT® MEP Specialist
Message 13 of 18
RobDraw
in reply to: debimmanager
The OP said that it was a cap on a pipe. Your example is showing the desired behavior with a cap on a fitting. Plus, he also said that he was changing the type from what is assigned in the routing preferences and then changing the size. None of which you did.
Rob
Message 14 of 18
hi, thanx for your video response.  perhaps no one understands my dilemma.  I place a plug/end cap called "my cap #1".
Then I change the pipe size & the cap changes to "Plug - PVC - Sch 40 - DWV" (or whatever is in the system as assigned default.)  My cap has parameters & stuff that now went "poof" in the schedule & I must (manually" find this cap & change it to "my cap #1".  Additionally, your video had a cap on a fitting.  my current situation is a cap at the end of a pipe section (floor cleanout).
Message 15 of 18
RobDraw
Actually, your OP was quite clear. @debimmanager totally missed the mark.
Rob
Message 16 of 18
RobDraw
BTW, this behavior is not unique to routing preferences. For instance, there are a number of ways in which the settings assigned to views can affect the properties of an instance that have had overrides applied to it when changing anything about them. Worksets and phases for instance.
Rob
Message 17 of 18
Yes, the hierarchy has given us issues in the past. Just part of the learning curve.
Thanx.
Message 18 of 18
debimmanager
Guru, sorry for my mistake and have a great day
Thank you!!
Deivis E.
Forma Design Contest
Technology Administrators
