Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Imported /link DWG file not showing up in revit
62 REPLIES 62
Message 1 of 63
cesslinger
294999 Views, 62 Replies
I have linked and imported a dwg file into my Revit MEP 2014 dwg. It is not showing up. I have checked my visibility graphics and my view range. I'm not sure what else I need to look at.
62 REPLIES 62
Message 61 of 63
justinNJ3YQ
It was definitely the **** light bulb!! Found it, thanks!!
Message 62 of 63
jimbell153
in reply to: mlampard
This did the trick.
Thank you for your help.
Message 63 of 63
This works for me:
When I link a CAD file with "Current view only" checked, "Orient to View" is greyed out.
So I uncheck "current view only" then change "Oriënt to View" It doesn't matter to what, as long as it changes (in my case). Then I check  "Current view only" again, and it works.
Same thing happens when u can't move a Model Pattern when "Disjoin" is checked. This option is greyed out when moving a pattern. But if you use the "Move" command on something else first, you can uncheck "Disjoin". Then this is also unchecked when moving the pattern and its no longer locked in place.
So probably there are some other issues that can be resolved with this same approach.
Hope this helps!
Forma Design Contest
Technology Administrators
