Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Call LOD in parameters
3 REPLIES 3
bri47744
152 Views, 3 Replies
Is there a way to set a parameter based on the level of detail set?
I need to set different visibility for different types, based on level of detail, in the same family.
(Yes, the easy way is to create different families, but I do it only if it's not possible)
3 REPLIES 3
curtisridenour
in reply to: bri47744
If you nest a family, the level of detail can be different. you can used a Family Type parameter in the container family to control which one is visible.
fabiosato
in reply to: curtisridenour
Be aware that this solution may bloat your model. The family file size can be significantly larger.
Fábio Sato
curtisridenour
in reply to: fabiosato
@fabiosato is very correct. don't use this method too often.
Forma Design Contest
Technology Administrators
