Is there a way to set a parameter based on the level of detail set?
I need to set different visibility for different types, based on level of detail, in the same family.
(Yes, the easy way is to create different families, but I do it only if it's not possible)
Solved by curtisridenour. Go to Solution.
If you nest a family, the level of detail can be different. you can used a Family Type parameter in the container family to control which one is visible.
Be aware that this solution may bloat your model. The family file size can be significantly larger.
Fábio Sato
