Wall Thickness in Door Schedule
Contractors are always asking for the door frame throat dimension (or wall thickness) in the door schedule. Walls report their thickness, doors know what walls they are in. Seems like an easy thing to make happen.
5 Comments
wr.marshall
As a workaround, you could maybe create this a a parameter in the family, thereby having to create a new type every time you have a new wall thickness.
YarUnderoaker
or use simple dynamo's script
alan_eu
Looks good!
szilagyi.balazs
Reporting parameters are implemented to solve problems like yours. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
lionel.kai
Since the functionality is already there, maybe this idea could be changed to "include 'Core Thickness' and 'Wall Thickness' shared reporting parameters in OOTB Door & Window families"?
