View tabs appearance and switching
I would like more control over how view tabs appear and how we switch between them:
  • Control tab width - set minimum, maximum, or standard tab width
  • Control tab bar display when full: scroll-able, define maximum number of extra tab bars
  • Control visibility of tabs by file, so if multiple projects are open at the same time, it's clear which tabs are for which.
  • Ctrl+Tab and Ctrl+Shift+Tab should switch through tabs in the order they were last used rather than the order they appear on the tab bar.
2 Comments
lionel.kai
I like the scrollable idea!
If not, force all the tabs onto the screen...
I'd also like to see smaller tabs - like just the sheet number for sheet views, or be a little more intelligent w/ what's shown (what differentiates view titles - like if they all start with the same thing, show the elipsis for the front/middle and just show the unique ends - SO THAT WE CAN ACTUALLY TELL THEM APART). Or if Revit doesn't have the intelligence to figure that all out on it's own (and adjust lengths on the fly), let us set the names ourselves (manually, or with an add-in).
