I know there's the view references tool but it's bad because you still have to use text notes to use it in a sentence. Example, if you want to say something like "See 1/A4.00 for Building Sections" you have to make a text note that says "See" and then place a view reference, and then make another text note that says "for Building Sections". If you type the whole thing out in a text note, then if your view gets moved to a different sheet than your note will not update.
It would be great if you could the place view references inside the text notes, like hyperlinks in a word doc.
The same thing with schedules, like when you're referencing jamb details on a door schedule, instead of typing them in as text, they should actually be referencing a view.
