Vertical Schedule Orientation
Be able to toggle from a horizontal oriented schedule (elements in rows, parameters in columns) to a vertical schedule (Parameters in rows, elements in columns). Currently Revit only supports a horizontal schedule.
This would allow more flexibility for what can be fit on a sheet. Vertical schedules especially makes sense for scheduling a few elements that have many parameters you need to schedule.
81 Comments
devonpowell
For example, an air handling unit schedule with only a few units, but many parameters to define the unit.
Yes please! We have exactly the same requirement for AHU's, fans, boilers, pumps, and a variety of other equipment. Currently we simply don't schedule these items within Revit and have to use our own Excel exporter.
Seems like a basic feature to me! Just flip the schedule vertical instead of horizontal. Thanks for suggesting 🙂
Yes please!
mcharrette
Observer
Definitely NEED this feature!!! PLEASE
A lot of mechanical schedules are oriented vertically to fit on sheets because of the amount of parameters needed.
adrianas
Definitely needed!
adbryson
NEEDED!
You know its bad when an AHU schedule might not fit on a 30x42 sheet depending on what a certain title block looks like.
I think it would be very very useful if Revit allows us to list the fields in a schedule vertically as well.
The horizontal format it is too restrictive.
ex:
Unit Area          0.00
Balcony Area     0.00
Total                 0.00
Rather than:
Unit Area      Balcony Area      Total
   0.00                0.00              0.00
Thanks.
Please let columns and rows be able to be switched.  Often the parameter description name needs some length and this would be much easier in a vertical schedule than a horizontal schedule.  Most of our standard schedules are vertical type so we are still using detail lines and text and missing out on the parametric power in Revit.  The Revit default horizontal equipment schedule is very hard to get right.   It looks terrible because different columns will have different  widths to fit the parameter description, and for most equipment ends up being too wide for the sheet, especially when our client makes us work on a 34"x22" sheet.
draynorQNHWR
This ranks in the needed column for me as well.  Large equipment with many parameters look ridiculous being broken up into 3 or for separate schedules just to get them to fit.
rickscUJPTB
I just listened to the "What's new in Revit 2019" webinar and checked the Revit Road Map.  I am really disappointed that schedule appearance and formatting is not mentioned on either.  Architects and engineers are generally very attentive to detail and appearance.  The lack of schedule formatting options gives us no alternative but to be chronically ashamed of our schedule sheets.
Basically, the entire engineering world has been using spreadsheets to schedule equipment for decades.  If we use Revit's equipment schedules it makes that no longer possible.  Therefore, there is no excuse for Autodesk to not make basic spreadsheet functionality, in terms of function and formatting available in Revit.
Autodesk is missing a major opportunity to revolutionize the way equipment data is managed.
devonpowell
This is the same idea as the below link, vote for both!
https://forums.autodesk.com/t5/revit-ideas/vertical-schedule-orientation/idi-p/7040737
lionel.kai
While it wouldn't completely solve your issue (based on the example shown), this would help a lot: Vertical Alignment option for Text in Schedules
devonpowell
Here is a pretty typical thing we have to do to break up out schedules and make them fit. This is scheduling 3 electric boilers....2019-04-15 07_41_45-Window.png schedule 1 of 2. Anyone have better workarounds?
We still use excel for ONLY this reason. I would really like to get away from that but not being able to format the schedules the way we want is unacceptable. For what a Revit subscription cost It's very disappointing that this basic feature has not been added yet.
Evan.S.Hall
@devonpowell, that looks like a pretty good workaround. This limitation has made my company become more selective when deciding which columns remain in the schedule. For instance, almost all of our physical dimensions have gone away since we model these elements very closely to the actual equipment. Additionally, we've combined some fields and grouped under a common header like what's shown below. This can really buy a lot of space with temperatures (if you can use abbreviations like EWT, LWT, EAT, LAT). I think you could squeeze your schedule down to one without much sacrifice.
All that said, this is a silly limitation.
On a slightly different topic, how did you create the general notes and specific notes? Something like "Insert" a row below the title, and merge accordingly? Or did you use some other magic?
adbryson
@Evan.S.Hallyou are correct on your notes assumption.  just insert a row or 2 under the title and then combine as needed to get the required number of columns.  Shift+Enter is your friend when getting the text to wrap as desired, and for each new note  😉
devonpowell
@Evan.S.Hall  - Agreed, and especially for that boiler schedule we could squeeze it down to one. Other pieces of equipment like an Air source heat pump with heat recovery modules it becomes harder. But good point on using abbreviations, etc. to shrink it down.
confirmed on the general and specific notes.
Please add this feature!
Yet another design firm not using the built in "smart" schedules simply because we desire a different orientation.
hstaabprime
Pretty please with sugar on top.
john.mckenna
This seems like a pretty obvious feature that has been missed / ignored for Revit!  It would be of huge benefit to most companies who want to use Revit to create schedules.  Please add this as a matter of urgency for a future release! 😬
