cancelar
Mostrando los resultados de
Quiere decir:
Variable thickness roof overhangs
It would be great to be able to have the roof overhang be a separate thickness (or even structure).
Typically, even if I'm using bigger rafters for a roof (e.g. 2x12), the soffit/overhang is 2x4 or 2x6 max.
I know of the fascia settings (which have their own limitations) and have worked around it other ways, but would be nice to have something a bit faster.
9 Comentarios
aaronBWC
Yes, please.
Our company deals with this on every project. We use 14" I-joist rafters for insulation value, and step them down to 5 1/2" outside the building envelope; at the eave and rake overhangs (nobody wants a 14" fascia on a house). This requires modeling two separate roof elements every time (not very efficient).
Thank you @artay4LN6E  for posting this important topic.
KhaledAlSayyed
Simply you need to select your roof and go to the properties panel. For the Rafter Cut under construction select (Two Cut - Plumb) and set the Fascia Depth at 5 1/2" or whatever you want.
aaronBWC
Thanks for the suggestion @KhaledAlSayyed , however changing the fascia cut will only cut the vertical face of the roof element to a specific dimension. It will not allow the entire overhang (the portion beyond the exterior wall sheathing) to step down to a smaller dimension. Something like this:
artay4LN6E
Exactly, thanks @aaronBWC !
KhaledAlSayyed
@aaronBWC
yeah, I see what you mean. I am not sure if there is any way to do this other than creating 2 separate roofs. However, I us the "plumb square" option and then create Detail Item (masking) in sections. If you want to have an exterior horizontal soffit, in this case you can use the "Plumb" option as-is.
artay4LN6E
@KhaledAlSayyed
Yep, got my own workarounds too. No easy solution for it currently, hence the idea that it be a new feature.
lmartinezZLC52
This something I have struggled with for a while, I use a variation of work arounds, some mentioned in these comments.  I see the original IDEA was posted at the start of 2021, how much attention is paid to this?
archijive
Observer
Even basic sketch up plugins can handle this.
sbailey
Observer
Here's my workaround:
Architecture: Build --> Component --> Model in Place --> Roofs
Name block according to elevation (such as "South Dormer Cut") if doing multiple
Set Reference Plane to Fascia
Select Void Form Extrusion
Create extrusion of what you would like to delete -- align inner edge to wall face
Cut
Finish Model
Paint revealed surface to match adjacent wall
Hide linework in view
Use hide lines
Enviar idea
