Usability Improvement: Allow View Template edit from VG screen
When a view has a template applied and you go into Visibility Graphics (VG), everything is greyed out. In order to then edit the View template you have to hit cancel, go over into the properties pane and click on the template to edit it. This is the kind of horrid UI problems that Revit needs to get rid of!
When you're in VG and it's all greyed out Revit should:
A> Tell the user there is a template applied (and which template). and
B> Allow the user to directly open the template from there. E.g. an "edit this template" button.
Glen
1 Comment
casquatch
Agreed! I feel that they should be somewhat one in the same, see my similar post here: https://forums.autodesk.com/t5/revit-ideas/view-template-improvements/idi-p/6383644
Sadly now it is archived. Maybe if we get some support, @sasha.crotty can bring it back to life or at least merge some like Ideas and get things going again.
Here is another that is very similar from @lionel.kaihttps://forums.autodesk.com/t5/revit-ideas/visibility-graphics-dialog-should-have-a-view-template-bu...
