Unlock Both Sides
Unlock Both Sides
If we could move both sides, would be very good.
Because, there are a lot projects that the CEILING are in diferents hight... so, it's necessary that the layers are in differents hight also.
2 Comments
ryley.g.h
This is needed! Different ceiling heights is one reason, but also GYP never goes down to the floor surface on either side, and often terminates at the ceiling finish on both sides, even if the wall structure continues to attach to the building structure above.
Come on REVIT/AUTODESK  you can do this! this program is hard enough as it is. Why not making it a bit easier!
