Unhide Elements from right click menu when hidden
Something I just noticed is that the option to unhide a selected element isn't shown unless you use Reveal Hidden Elements first. I went into a 3D view to select elements to hide in an elevation and did the same thing to unhide an element I accidentally selected along with the others but the option wasn't there until I turned on Reveal Hidden Elements. I then had to go back to my 3D view to select the element again as it was behind other elements. The option to hide an element should become unhide if the element is already hidden.
1 Comment
rolandga
We need this. In complex projects Reveal Hidden Elements gives us crazy red mess where you hardly can't identify anything manually. It is a much better workflow to select the element in a view where it is visible already, then switch views, right-click and pick Select Previous, then right click in empty space and Unhide. Why can't we do this?  I wish for the next Revit version to just fix all the annoying little tedious workflow things that make us tear our hair instead of introducing a bunch of new features.
