Duct taps need to be attached message
When I upgrade my model from 2023 to 2024 I get a warning dialog box stating "The Tap must be attached to duct." if I click OK I am not able to find where the tap is that needs to be attached. Is there a way to find these taps that are not attached? Is there a way to get that warning dialog box to appear again? I have tried to find them in the Manage tab>Inquiry panel>Warnings dialog box and the Analyze tab>Check Systems panel>Show Disconnects. But I am unable to find the warnings. If I continue in the file and save the project, close it and reopen it, the warning dialog box does not appear even though I have not fixed those taps. You guys have a blog stating that the duct branches and the main ducts elevations are slightly off which is true in my file. I just wish I could click OK in the warning dialog box and find them again when I am ready to fix the taps. The only way to know which taps in my project are not connected is to export the error report when you first see the Tap must be attached to duct message when first opening it.
This is related to CaseNo:20510109
