Show only
Search instead for
Submitted byAnonymouson11-30-201611:26 AM
Status:
Gathering Support
Truly "Curved" Mullion/Panels Vs. "Faceted" Mullion/Panels
It would be great if the horizontal mullions and panels on a curved wall could have the option to be rolled explicitly to that curve. Currently there is a break for every gridline, and that is the only option we have, which is rather annoying
The whole curtain wall tool needs to be re-worked. Vertical mullions do not stop at the bottom & top transoms, it is just the cappings. Vertical mullions are not broken at every transom intersection. We need the ability to define where mullions are split and connected with a spiggot connection, as stick assembled curtain wall bars typically come in 6m maximum lengths.
Creating Curved panels is easy enough by setting the Panel to a Wall Type. However, having a mullion follow the curtain wall curve is not so easy. There are numerous workarounds, however I typically use a Wall Sweep to do this. But ideally you should be able to select a curved segment of a Curtain wall and access options for segmentation, similar to the family environment for sweeps. Then set the number of segments to 0, would make the mullions and any System Panels follow the true curve for that segment.
