TOP VIEW ( floor plan view) - When duplicating - remove opening every single view when duplicating
Duplicating top views for walls often but it would be nice if it wouldn't open every top view you duplicate.. I already know I'm duplicating, I don't need it to open every single top view. Slows your pc down especially between projects.  Modular building I'm dealing with 100s of top views! Just an efficiency note.. Same thing for duplicating new sheets.. Slows things down when its not necessary to open when you already know its going to be there. Making 20 sheets in a row i don't want it to open every single one and show it to me.
Include a setting somewhere to toggle this off and on would be awesome!
1 Comment
Ric_Weber
I'm imagining basically a doubling up of options (duplicate, duplicate and open, duplicate with detailing, duplicate with detailing and open, duplicate as dependent, duplicate as dependent and open).   Regardless of how they want to set that up, having all of those options easily accessible would be the key because, "sometime you feel like a nut, sometimes you don't".
Here is a similar, but basically opposite idea that when creating a new view, not duplicating (section, callout, elevation) that you have the option to open those views right away.  https://forums.autodesk.com/t5/revit-ideas/automatically-open-section-views/idi-p/11134661
So basically what it all boils down to is we all want options.
