Text Length Parameter
Allow text blocks to have a parametrically defined length. Labels and text fields often have varying text lengths, and it would be nice to allow for different graphic lengths depending on placement and surrounding conditions.
12 Comments
Johnathon.Page
Second this, it is evidently there as you have drag boxes the API guy's just need to make it available to the user to parameter.
Also want to second this and give it a bit of a bump. Seems like a basic feature that could help immensely  with making annotations more clear and user-friendly.
This would be great, to allow selecting all text boxes on a sheet / view and set the length to be matching -- rather than having to adjust every one of them manually, as we do currently.
rookio
Bump - This needs to happen. Would open up so many possibilities
It would be great if it would possible to add a length parameter to the size if the text boxes or labels. Or at least align it to reference planes so that they flex.
I want to create an annotation family with text notes inside of a box. and I would like to adjust the box and when i adjust the box, I want the text to adjust as well. What we have to do now is to manually adjust the text box to fit in the box.
I hope that I am clear in my explanation..
mark.mountain
Autodesk need to get on this. At the min the work around i use is 2 tags in the same family. one long one short. then have visibility parameters to switch them off/on. its not perfect but the best of the options available with current revit limitations. just once you start introducing different sizes of tag and a left sided tag or a right sided tag depending which side the text is on in details. Your tag family starts to become complex.
EmptySaturnV
We have standard notes that we use on plans and we have created generic annotation families to address this. This is especially necessary when changes are made to notes and need to be carried across many plans and it enables us to just reload the annotation family. From time to time we need the "family/note block" be stretched to a different size just as you would do with standard text. Can this functionality be added to stretch generic annotation/text families? Or does this functionality exist, and I've never seen it?
Tags (2)
anielson
Yes! I have wanted this so many times. Right now I want to make a shadow box note detail component.
This needs to be fixed!! Ideally to be able to drag tag width visually after placement like a text note. Or to choose to associate width to Instance/type parameter in family editor.
g_thong
Definitely need this - I would have thought autodesk would have picked this up in the past 6 years! We currently have 6 different keynote family types just to achieve this (Left-aligned small, medium and large and right-aligned small medium and large).
vdaskalov
I would deeply appreciate this functionality.
P_boz
Proposition d’amélioration pour Revit
Il serait utile de permettre un redimensionnement indépendant des étiquettes, offrant ainsi une plus grande flexibilité dans la gestion des retours à la ligne entre les attributs.
Bien que l’outil actuel soit fonctionnel, une refonte pourrait améliorer son adaptabilité et sa flexibilité lors de son utilisation sur les plans.
Customizable Label Resizing
Improvement Suggestion for Revit
It would be beneficial to allow independent resizing of labels, providing greater flexibility in managing line breaks between attributes.
While the current tool is functional, a redesign could enhance its adaptability and flexibility when used in drawings.
