On behalf of the Revit User Group DACH, which represents hundreds of customers, we ask for more flexible stairs, especially the monolithic stairs in Revit which lack a way to model and edit the correct shape of the riser base and top end connection profiles to meet the required constructions.
With that higher flexibility it will also be possible to align the kink lines of two runs of a staircase what is also key for Architects.
Picture number 1 shows three ways of stair base end connections that are possible at the moment, but those are neither meeting standard requirements nor possible to build (too sharp or finishing floor not possible to build):
Picture number 2 shows examples of required correct stair bases (end connections) that are not possible to model with Revit stairs functionalities, those were modeled as in-place families.
Picture number 3 shows a further example of a required stair end and top base including connection notch. The main focus here should be the requirement of aligned kink lines.
